Ok im not near my car so I cant check.. and I want to buy. What is everyone running and what pipe dia am I looking at?
Does it get cold enough in sydney to require a thermostat?
Going to route to new cooler then through rad...
Edited by m35stagea
https://www.sau.com.au/forums/topic/423580-m35-transmission-cooler/
Repco - they sell re-branded PWR products. Get them to give you their catalogue flick through and pick the one you want.
3/8ths from memory. Thermostat is neither here nor there. Depends if you are driving 10 mins or 30 mins to work.
Running a Derale Series 7000 cooler on mine with one of those blue thermostats (I am also incorporating the OEM radiator inlet/outlets before both the thermostat and the cooler)
Comes with 3/8 hose but the barbs out of the transmission and OEM radiator are 8mm so recommend to get some 8mm clear plastic hose from Bunnings etc to use on the barb as a liner which will will out the inside of the 3/8 hose.
Why did you go radiator before the aftermarket cooler? I would of thought it is better to take some work off the radiators in these things?
Take work off the radiator? Man, I can only get over 80 degrees coolant temp if I sit on the side of the road idling for 5+ minutes.
What will happen with the external cooler before the radiator is that you will possibly be warming up the trans fluid on its way back to transmission.
Most efficient way of cooling is to have the ext cooler on the return line back to the transmission. If you are concerned about it getting too cold, just use a thermostat.
I was under the impression vq's had issues with cooling?
Just ordered 20L of matic j for 176 $ + gst so ill do cooler with shift kit... I noticed yesterday it was fairly warm and car seemed to feel it. I also noticed the clutch fan to be alot louder..
what side is the transmission inlet and outlet ?
They do run quite warm... without the cooling mod from Scott.
The line that enters the passenger side of the radiator is the trans outlet.
The problem with our auto is that it needs to be up to operating temp before it works right. If you go removing the line from the radiator or cooling the fluid to a more sensible temperature, it will drive like crap, or worse never drop in to 5th.
The way I got around it was to cut the two temp signal wires at the TCU and drop varisters over them. This tells the gearbox it is already at operating temp, allowing me to cool the fluid as much as I like and the bonus is it doesn't go into overheat limp mode on the track anymore.
  • Like 1
I love those kinds of mods - big win for little outlay. Not necessary for me but I like it anyway :yes:
Edited by Commsman
  • 3 years later...
Does someone still have an active link for those thermostats? Or possibly the suitable operating temperature for them? I see there are a few options out there including single inline type or supply and return type thermos, could anyone recommend what to go for as my set up will be stand alone cooler seperate from the radiator, hoping to fit it in somewhere behind the grille but always open to more advice, many thanks
http://www.amazon.com/dp/B008BTJFJ4/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687582&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000HE8HAY&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=03CJAYFFKWJZ02F2ND8S
The trans thermostats we used? Those ones linked, but there are heaps of different designs, most of which take up a lot more room.
Loading up the radiator by fitting coolers in front of it will not only make the radiator ineffective but overheat your aircon condensor too. Shame there are no side ducts. :/
  • Like 1
Need the Nismo front bar; a bit of side ducting there...
  • Like 1
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
