Hello,
this is my rb26/30 build
by kanaris engine in melb
rb30 block - cryogenic block and girdle
cp pistons
9310 pins
upgraded loxx by cp
carrillos rods
AT1 balancer
L19 Head studs
Jun 12 main studs
9L sump ASR
Billet motorsports external oil pump kit
annual groove main tunnel
Head getting done now
2mm inlet/2mm ex valves
supertech valve springs seats retainers
ferrea valve locks
tomie 260/270 cams 10.25 lift
tomei lifters
tomie cam gears
looking at 1000hp at the engine
going in vl
  • Like 1
https://www.sau.com.au/forums/topic/423779-rb-2630-build/
I always thought running flat tops means u can run more lift.
comp ratio going to be around 7.8 to 8.1
reason that low comp - less pinging high boost ,
makes more power then high comp - all types of fuel
I notice a lot of high comp boost rb have head/studs lifting issues
allways prefer low comp high boost/ high comp low boost
https://www.sau.com.au/forums/topic/423779-rb-2630-build/#findComment-6823429
  • 1 month later...
  • 3 weeks later...
I here'd about weathering/seasoned blocks are better for hp than new block for cast iron - new block will move and flex up until 100,000km
Idea is the hot and cold temp stop the cast iron from expanding/ flexing - taxi blocks would be good idea
I left the rb30 block outs side for 6 months bare wit the girdle and just befor sent to engine shop I went to cryogenics
I believe this theory works , some might disagree
crank wouldn't think be any benefits
only cost $200 shop in melb -http://www.cryocycle.com.au/
Gerry
Edited by chairman
https://www.sau.com.au/forums/topic/423779-rb-2630-build/#findComment-6922218
  • 4 weeks later...
