So I'm looking at getting some direct replacements for the OEM injectors for my r34 gtt, the injectors I have in there now are wide open after a terrible tune and the car isn't keeping the fuel up, I'm trying to sell it and want to throw a quick set of injectors in and get it retuned so its better for the next buyer and I was wondering if anyone knew where I could get some direct drop in top feed injectors for the standard plenum as like I said I just want to spice the car up a little before it goes and don't really want to fork out for a new FFP and fuel rail on top of injectors and end up spending way more than I need to, I'm looking for something I can take into my tuner and let him deal with as I don't want to take out the ones already in there to send away and get high flowed because I need the car running to drive it up to him, any help would be much appreciated!
Cheers.
Well if you're planning on installing them yourself and driving it to the tuner, then that won't be possible with anything bigger than factory. If you just want to drop the car and the injectors off at your tuners and let him install them, then you've got a couple of options. Siemens Deka injectors are a direct swap over, very simple. Power Enterprise 650's are also a straight plug in item.
However myself and many others on here will recommend ID1000's. They are almost a direct plug in item, but they do require different connectors as they use a square plug rather than the OEM oval plug. This is in fact extremely simple to do, the injectors usually come with the required plugs and all you or your tuner has to do is disconnect the old plugs and install the new ones. Takes half an hour if that.
Thanks a lot for the info Honaldo, with the ID1000s being 1000cc will they be okay only running at 280-300rwkw as the turbo I have on the car right now isn't going to give me much more than that. Also is there any sites you would recommend for sourcing the other brands of injectors for better prices etc? Thanks again
Update I had a look and found some DeatschWerks 850cc online which claim to be a direct drop in but im not sure how reliable they are and also sourced some power enterprise injectors on nengun but couldn't see the 34 as one of the listed applications although the 98 stagea 25t RS four was, I'm not 100% sure so correct me if I'm wrong but don't they run the 25neo motor?
The ID1000's will be fine at that power and give you room for more if you or the next owner decides to chase more power or go E85. The ID's actually give you a fantastic idle, and I get around 550km's to a full tank just cruising around.
The DeatchWerks are also a popular choice. With the Power Enterprise,the 650's I used in mine were actually for a WRX. Injectors aren't really engine specific, so long as they are top feed and high impedance, and a similar size to factory; ie. length (mine were 10mm longer) and o-ring size, then they should work.
Thanks again for all the info mate I think ill keep it simple and just got with the DeatschWerks 850s as they'll be quite enough for now and I've seen a lot of people run then without any complaints, like I said if I was to keep the car it'd be getting a complete overhaul with a FFP, new fuel rail and much bigger injectors but just for the sake of putting a big more into it for the sale and making it a little more appealing I think this should be plenty plus the stock injectors are very much at their limit. Cheers mate!
I was under the impression bigger injectors don't really work as well as smaller ones for low end power or the lower rpm range? Something about the spray pattern no being as uniform and misty with the bigger ones. Just how low can you go with 1000c injectors if you don't have big mods or big power but want to future proof.
I got these
http://www.ebay.com.au/itm/Nissan-skyline-NEO-r34-Stegea-350z-370z-infinity-g35-bosch-750cc-Fuel-injectors-/200906279410?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec6f289f2&_uhb=1#ht_2093wt_1271
D
elivered in a week, car idles and drives a treat, It starts better than it did with stock injectors, lol
They are flow tested and each one has a report, also they are tested at stock fuel pressure, so no need for stupid fpr's.
I put out 320 rwhp without trying with these.
I got these
Delivered in a week, car idles and drives a treat, It starts better than it did with stock injectors, lol
Very nice. Thanks for this. Is there a version that bolts as easily into an S1 r33 gtst-t running the stock ecu? i didn't know you could use 750cc injectors without an aftermarket ecu.
No, there isn't. You must have a tunable ECU to run big injectors. (OK, that's not quite true. Back in the 90s there were some desperate bodgy methods for making them work, but ignore those as being stupid in this day and age). R33 ECU cannot be made tuneable, therefore you need some other ECU (aftermarket or a Nistuned R32/Z32 being the choices).
I only ask because on that ebay link i read
"Kit is drop in fit for the following vehicles with no modifications needed to install. The injectors sold in balanced sets to insure cylinder per cylinder horsepower equalibrium. The injectors are high impedance which will work perfectly with your factory ECU:
Now, more to the point, those injectors in that eBay listing are to suit a Neo RB25, which is not the same thing as an R33 RB25. For one thing the injectors are completely different between the two engines (side feed on R33, top feed 3/4 length on the Neo) and for another thing, the Neo's ECU is able to be converted to programmable (via Nistune) and so yes, you can run bigger injectors with the factory ECU. But you can't do so until you actually put a Nistune board in the ECU and tune it to suit.
Edited by GTSBoy
That used to be true, and is still true of the larger injectors still based on older designs. But the new Bosch ones, and many of the modified versions of them, work very very well. People even get beautiful idle off the 2000cc injectors.
Yep i installed 2000's in my evo 9 tonight and they are spot on even with only bout 15-20km of road tuning :)
You need 50% bigger injectors for the same power level on a 4cyl than you do on a 6cyl. Add a big power target and e85 to the mix, and you need big injectors. He probably doesn't _need_ 2000cc injectors, but the fact that he _can_ have them without any problems might be a good enough reason to use them anyway.
why do you need 2000s on an evo :S? lol
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
