Hi All,
As you may or may not be aware, we are reviewing the Pro's and the Con's in moving our forum back to the Mothersite (www.SkylinesAustralia.com). This is a decision we are taking very seriously as this will influence the way the club operates. As the execs are not here to dictate rather facilitate the running of the club, we require the decision in the move to be voted on by our members.
The discussion is open to all members of the forum to participate, however voting is only open to paid members of the club. A blind poll will be launched in the up coming days and all paid members will be notified on the poll.
Here is a list of Pro's and Con's for moving our forum back to the Mothersite.
PROS.
  • Public Exposure
  • Traffic flow
  • No cost to the club to host our forum
  • Constant update to the forums - free of charge
  • Separate members area to be arranged in any way we deem suitable
  • Our own moderator within our club area
  • Page can be laid out as we wish
CONS.
  • No Admin control
  • No ability to email from the forum
  • Previous tainted history between SAuQLD and Skylines Australia Moderator/Admin team.
Here are a list of Pro's and Con's for keeping our forum on SAuQLD.com.
PROS.
  • Admin rights.
  • Mass email
  • Can layout the forum as we wish
  • As many Moderators as we wish
CONS.
  • Low public exposure
  • Low traffic flow
  • It costs the club to host the forum
  • Forum/site Updates required may need to be purchased
  • Less ability to do forum membership recruitment
  • All forum maintenance is to be completed by us
  • Less likely to build a rapport with other states due to lack of presence
As this is an important club decision, we encourage discussion and want to know your opinions before a decision is made. So please spend a few minutes thinking how this move will impact you and your club and feel free to ask any questions you may have.
Cheers
Scott.
Scott/Tony *raises can of redbull*
I believe my view has already been expressed many times over the course of the last month or so, but in my opinion we as a club would be better off moving our banter as a whole back to here.
I see no reason as to why members who frequent the whoretown/forum on the SAu Qld site can't simply migrate over here and talk the same level of er intelligent discussion in these forums.
So looking at it from that pov we have alot more to gain (a much larger base for members to come from) than what we have to lose.
Admittedly losing some of the exec moderator control is annoying, but moderator control can be delegated to specific sections of SAu Aus so why not simply limit our moderator power to the qld sub forum?
Basically I'm all for moving us back to here :)
There's a lot of... interesting... banter going on over there about this.
Yer I'm flipping between the two sites as I type now.... The problem is none of them will ever see this post AS THEY DON'T COME HERE!!! :rant:
CONS.
As far as I can see, this is the only valid reason to keep a separate forum. I think some adult discussion is required with some assurances from SAU that we will still be free to moderate our part of the forum as we collectively see fit. Things can often get rather awkward when dealing with power-hungry keyboard warriors... Thoughts?
This discussion has been had, between members of the executive and admins on this site. We believe that this issue will not be a problem any more.
Name names please Martin, who are you dealing with????
Names aren't important, all we need is confirmation that they'll let us run our own show... Which I cant see any problem with, why not let us run the qld section we're the ones that live here ?
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
