Thanks to JEM and SAU execs for the great night. I was the guy asking too many questions about circuit cars -sorry!
I also found Nitto's pitch interesting, learnt a lot about forged internals etc. It was also interesting that he didn't mention any prices which I found amusing. Hopefully I will see you all again at the next track day when my car is up and running :)
never too many questions.
I was actually a little surprised at how few questions there were.
the talks were very in depth though.
, on the nitto front, if you have to ask.....
Had a great old time.
+1 for the guys at JEM putting on the night. Wasn't expecting it to go so late, but there was a lot of info to get through. Put the tech in tech night at some stages!
Was interesting seeing/ hearing tuning philosophy's and personal prefernaces.
I was going to ask Andrew about whether or not a balanced billet crank negated the need for a damper pulley kit on some cars - but Eric seemed to answer it for me before I could get to Andrew privately.
Bit shy still at my age hehe...
I did have a talk to one of the JEM staff at the end.
He himself could have given the type of talk on builds that Andrew gave being an RB specialist full time at JEM.
I'd like to hear him next time.
All the speakers were superb! :happy:
+1 thank for all involved.
The best part of it was that every answer was explained on a level so that a novice could understand. Even if a few questions were very technical.
Really well done.
I'm now more not sold on E85 for the costs. Great in a new car, but the $ to convert seems too high.
Plus, I'm convinced that once Julia see's it becoming popular, she'll slap tax's on it so the cheap bowser benefit will disappear.
Thanks to everyone at JEM and the execs at SAU for organising!
Was a fantastic night, covered a lot of bases and such a variety of topics.
Bobby's new project is absolutely incredible in person. Can't wait to spot it at the local Coles sometime soon! :)
Edit - great photos guys!
I wasn't able to get many shots in - no experience shooting cars but guess I can change that :P
Spent most of my time meeting and greeting and a big kudos to Nick for the lift home :)
As covered by other people, not many questions were asked mostly due to how in depth the talks were - very informative on a lot of areas and also the openness of what goes on too. Z Tune and "Skola Tune" GTRs were very impressive.
"Tomei" GTR
JEM Insane Spec GTR :P
Z tune officialdom:
Terry's Nismo Strut Bar (for those who are curious)
Terry's Engine bay which has been seen before :)
Wow looks like it would have been a great night, I'm kicking myself for pulling the pin, the Tom Tom said I would get there just after 9 so I pulled out thinking I look like an idiot pulling up as everything's rapping up. Looks like I missed a top night.
haha I had the same problem, was way late due to M5. On the bright side I missed most of the nitto bit :)
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
