Hey all,
Just wondering where a good place to get a skyline service done? My last one was the major at 100k, and im ashamed to say I haven't serviced it since then (currently at 120k).
I have a '98 34 GT-T and live in Western suburbs NSW, and an approximate price range for one would be appreciated too.
I know i need a coolant flush and to clean out my radiator cos it's got leaves, bugs etc in the fins, and i was quoted $175-185 at TSI. But i was thinking I may as well go for a service since i'm over-due for one too lol.
Cheers!
https://www.sau.com.au/forums/topic/424208-where-to-get-a-service-done/
Mate I know a bloke that works from home/old shop , that is a mechanic and services cars for cheap as. and has specialist knowledge in rb26/25/30/20 he can do everything u want if ud like a number inbox me ! He owns a gtr himself and builds them from the ground up he is at rooty hill I think!
that sounds awesome! right down the road from me. Inbox please :)
Just Engine Management :)
thanks mate, but Ingleburn is a bit far from me
$150 you can get a new upgraded radiator. cheaper, easier, better =)
I was considering buying a new one, however it's flushing my coolant system that's a problem. I've had a search on these forums and can't find definitive tutorial on how to do it. Everyone is saying to do it different ways :\
yep my water pump was changed.
The reason why i want to change my coolant, is because i had a look in the coolant reservoir and there was nothing in there. Was going to simply top it up, but had a read around the forum not to mix two different coolants. I'm not sure what's in there at the moment, and i'm scared my car will overheat soon without any in the reservoir.
And the radiator still has sutff stuck in the fins lol.
Its a good idea to ask around IMO as some places will rip you of or worse not do the job right if they see you aren't very knowledgeable.
I'll take 500hp up on that RB mechanic offer as well. I need a few issue/minor upgrades sorted with my car. I'd love to work on my own car but I don't really have the place or tools to do it at the moment.
About your coolant, go super-cheap and buy ready to pour premixed light green coolant. Any brand. Seriously your more scared of mixing coolant than running out of it ? :woot:. Nothing bad will happen mixing it, or even not flushing your coolant for ages, but running out of coolant bad stuff happens.
It is probably the least sensitive fluid in the car as long as you have it in there. Its not like oil which IS important and not to leave for 20,000km... :domokun: You coolant doesn't break down or change properties over time like oil, and even if it does water is a better conductor of heat than coolant anyway. Even if you have just water in there and everything rusts it will still work for decades because the rust will form a protective barrier of scale against leaks lol.
Ive found in the past if you flush a rusted coolant system you can have problems but leave it alone and it just keeps going.
Anyway, good luck. The bugs in your radiator etc, are next to a non issue. Unless you have entire birds or chickens stuck in there it will work just fine. You can clean it yourself to a fair degree at one of those car wash places or with a brush.
Oh I think I've got a fair bit of good coolant left if you cant get yourself to buy it lol.
Edited by sonicz
Yea mate his number is 0427 168 857 just send him a text asking if ud be interested in what ever work u want done and her will help you he is a young feller and will do it in front of you ! Has the tools and the gadgets
Top it up with water. Demineralised if you're fussy, but anything will be better than nothing.
Have you seriously not changed the oil in a turbocharged Nissan engine for 20,000kms?
I've changed the oil every 5000km and also changed my fuel and air filters.
I haven't touched the coolant though lol.
sweet, thanks for all the info guys! I'll go grab some pre-mixed and top it up (:
So i've just spotted a coolant leak somewhere in my system after filling in some new coolant.
It's splattered around the airbox area, but more so underneath it. Not real sure where to trace the leak to, it's too dark to see at the moment.
This sucks :(
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
