With all these acusations and new hoon laws coming in the time has come to have full GPS tracking high definition video to keep your self safe on the road
Price will be around $139.95 per unit (give or take $10 as im still negotiating with supplier)
- 1st run will be of 5 units (can push to 10 if there is interest)
- $50 deposit up front for order
- All units will be sent directly to myself then i will send them out (easier to track that way)
1. Damo
2. MBS206
3. Ravi
4. Birds x 3
7. wedge_r34gtr
8.
9.
10.
Unit consist of 4 IR for night driving and has a 1.5" LCD for viewing on the spot
Specs/details will be below
Key Features
120 degree ultra wide angle lens, focus range from 10cm to infinity
1920×1080P full HD high quality resolution
Advanced H.264 video compression technology
5 mega pixels CMOS Sensor
1.5 LTPS TFT LCD, high definition, can watch while shooting
4×digital Zoom, ranges from 12 cm to limitless distance
Support HDMI high quality video transmission
5 resolution forms can be changed for video flow
30/60 frames per second for smooth video flow
Equipped with special auto suction cup holder. Conveniently fix and use
Built-in GPS logger, and google Map, can record driving track and so on
G-sensor to keep records of sensor data and real-time display on the player.
Matching IR Light for supplementing light at night
Seamless continuous recording, will not miss any data
Powerful document protection, even in the recording process, the occurrence of sudden power outages, machine damage, etc., video files will be intact
Adopt auto cigarette lighter power supply, to make the video recording while driving
To start the auto automatic off; to start the video recording function
Automatic circulating video recording, being able to set the recording time for each file
Watch video while ma king video recording in driving. Support on-spot play back
Improve time & date display, no need to reset when re-start
Set the video recording time, stop recording when the setting time is up
Screenshots function, can capture the video screen while video recording and reviewing
To charge through USB
Human orientated operation interface
Maximum 32G or even bigger SD high capacity storage device
Specifications
LCD Display 1.5 TFT LCD(4:3)
Camera Lens 120 degree wide angle, 4 fixed focus Lens, aperture 2.0,focus 3.4mm
Sensor 5M CMOS Sensor,1/2.5 light-sensing surface area
Zoom 4×digital zoom
Video Resolution H.264 compressed format1920×1080,30 frame/sec1440×1080,30 frame/sec1280×720,30 frame/sec848×480,60 frame/sec848×480,30 frame/sec
Video Codec H.264
Picture JPG file format Maximum output pixel:5.0 mega pixels
Circular Video Functions Support
Y/M/D/H/M Support
Carrier Media Built-in Memory (Available:21.1MB,Total:32MB)
Photograph Mode 5 mega pixels CMOS
Audio Microphone and speaker(AAC) equipped
Memorizer Memory:32MExternal Media: SDHC(support 32G max), TF card
Flashlight Automatic/Manual on/off electronic video supplement lamp(LED)
Video Output AV-OUT / HDMI out
Video Format PAL/NTSC
Current Frequency 50HZ/60HZ
USB Function 1. Memory Card2. PC camera
Shutter Electronic shutter
Battery 500mAh 3.7V Polymer Li-ion battery
Package Size 18cm*14cm*9cm
Bank details for payment
NAB
BSB: 082620
ACC: 136401639
ACC Name: Damian Hunt
Please PM me receipt details once payment is made (so i can find it)
- $50 deposit is fine or can pay in full if you like
Edited by Frosty
https://www.sau.com.au/forums/topic/424544-group-buy-full-hd-ir-dash-cams/
I'm interested...
Can we see it setup in the car?
How intrusive is the system?
non intrusive and can be hard wired if you like. Easy to remove (just like a gps)
comes with software that shows tracking on google maps (puts a little car and shows ur course etc etc)
Thank you Damo!
Old man, I can send you the one of the other cameras Damo and I were talking about last night... Captain Slow from TopGear reviews it... It's a 30 minute video... LOL
Excuse my ignorance but how do you come to this conclusion?
Someone says you did something, you have video proof you didn't. You keep yourself safe on the road that way. Is that not obvious?
Thanks matt
exactly that, given that (most) of us in the car scene are a tight nit community and the fact that there is alot of targetting at our cars etc this is a great to be able to prove otherwise
and this isnt just video proof. GPS tracking shows your location with GPS co-ordinates and on google maps including date stamp, speed, time.
Edited by Frosty
Added benefit, all the stories we tell each other of "On my way to work, this retard did this thing you'll never believe!" well now we have proof for those stories too! LOL
  • Like 1
So you will be recording me? :( lol...
Guest
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
