You sort of need the timing chain... Why would you need to rip the pump out?
The stock fan provides way more flow than any thermo setup...
Timing chain?? Huh???
Re clutch fan, Its noisy,
Takes up room for other shit I.e catch can could sit nicely in front of motor.
There is plenty of room under the airbox for a catch can.
The stock fan is noisy because it is moving a lot of air. Have you seen the blades? A decent thermo will make more noise again and use more energy to flow less air. The series 2 M35 uses two large thermo's but it doesn't run as hot either.
The water pump runs off the main cam chain, and provides an idler function. You can't remove it or your engine won't run.
I have twin davies craig thermos with a custom shroud. If you decide to go down this path, then a shroud is a must. I also have a large alluminium radiator and with all of this replacing the standard set up there is very little gain in space in the engine bay...if that is your main reason for doing it.
I'm using twin thermo's in my C34 S2, only because i'm using a 2 core aluminum radiator. Also using a custom alloy shroud too.
To turn the the fans on i'm using a fan controller. They make more noise than the standard fan.
Oh I forgot you car has chronic overheating problems at anything other than street driving. Probably why the clutch fan is stuck on all the time.
Maybe some well designed twin thermos, say off a pnm35 might be able to sort that. :P
Try running that power and see what temps your engine gets to. (Oh, that's right. Glass bottom end, sorry)
If I was to run twin thermo's, the V35 setup you have would be the obvious option, but I have no need atm. I prefer to see results from my modification, not go backwards. :P
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
