Ah right.
Are these pics of an old build? Looks similar to a car that was built by PAC.
It does look similar to the PAC r33. My car hasn't been running yet. You may have seen some pictures before its coming up to 4.5 years build time. Think Plazmaman had it as there profile picture on Facebook for a while. This is the Blacktrack Performance R33.
Not long now before a start up. Maybe/ would of had it out for Jambo next month in Queenland. But family has to come first as we have just had another baby girl. So hopefully before the end of the year you'll see this thing out and about. Windows are in. Everything's wired up. Few little things left. Then dyno time.
D76CAEFE-320F-4473-BB04-ECA1FCBC6CB9-136
3193CC96-3888-4AB3-8C44-95886A3F6A59-136
674A4D0D-34D0-462E-AC20-05DA05F1BA88-136
All fits behind the standard front bar.
F98B58F8-3E26-4489-8221-71B3C73E6E2F-136
  • Like 1
Awesome build
Always waiting for updates on your car
What size & brand is your cooler
Hope you get some videos when you fire it up / on the dyno / and most important of all when you let it go down the drag strip
Intercooler is a Plazmaman race spec unit. 1400hp. 600mm x 300mm. 100mm thick.
  • 3 weeks later...
  • 3 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
