Ah right.
Are these pics of an old build? Looks similar to a car that was built by PAC.
It does look similar to the PAC r33. My car hasn't been running yet. You may have seen some pictures before its coming up to 4.5 years build time. Think Plazmaman had it as there profile picture on Facebook for a while. This is the Blacktrack Performance R33.
Not long now before a start up. Maybe/ would of had it out for Jambo next month in Queenland. But family has to come first as we have just had another baby girl. So hopefully before the end of the year you'll see this thing out and about. Windows are in. Everything's wired up. Few little things left. Then dyno time.
D76CAEFE-320F-4473-BB04-ECA1FCBC6CB9-136
3193CC96-3888-4AB3-8C44-95886A3F6A59-136
674A4D0D-34D0-462E-AC20-05DA05F1BA88-136
All fits behind the standard front bar.
F98B58F8-3E26-4489-8221-71B3C73E6E2F-136
  • Like 1
Awesome build
Always waiting for updates on your car
What size & brand is your cooler
Hope you get some videos when you fire it up / on the dyno / and most important of all when you let it go down the drag strip
Intercooler is a Plazmaman race spec unit. 1400hp. 600mm x 300mm. 100mm thick.
  • 3 weeks later...
  • 3 weeks later...
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
