I'd say it'd be killer mid-range and up-top, really low down (ie, sub 3500rpm) will be where it'll be giving anything away to GT28 and trimmed GT30 turbines and the difference is not going to be in fail levels, by any stretch of the imagination.
that's what I meant by saying it will be easy to keep on song....
I think there will always be a call for the GTRS / 2835 style response in the hills though...
In terms of spool on the dyno it was never going to match exactly, even with the boost curve nailed - but within 500rpm, more likely. In terms of transient response it may be closer again, but having a full size GT30 turbine and larger a/r will always keep it a little less snappy at lower rpm. Once on the boil it'll be gravy :)
The overall performance will be interesting, however!
Lol i like that! :yes:
Haha don't take it to heart bro everyone has a crack at everyone on here lol. No big deal. Plazmaman is the way to go anyway. And after looking at my receipt my plazmaman throttle is 66mm the smallest. If someone ever buys my 2535 HKS I'll be putting on roys greddy t67 or a FP 3076.
Lol yep, i wasnt meaning anything by it :P
Oh and get a damn FP3076 so we can see some results haha
  • Like 1
With the power potential the FP 3076 has i think any hill will be fun :P
cant wait to see the finished graph for it...
that thing on an RB27 would be the tits
That would be potent!
I'm sure if I prattle on about it enough someone will give in! :D I almost did it myself, and have half considered going back to the idea as I still have the car.
Well it worked with Bri73y but because of non-turbo related reasons he hasn't managed a full dyno session out of it so far, though from what I hear there may well be a result sometime this week :)
I really want a fairly responsive 350kw on e85. I could live with a little less. I'm just going through my options. HKS 3037s 48t FP 3076 And a gt/gtx3076. The HKS is only t25 though correct? Where do you live Joey Melbourne? I'd love to go for a ride in your car to feel a 2835 pro s.
You mean actual variable nozzle tech? If so, I love the innovation but there is no way I'd run or recommend one until they start showing any sign of realistic longevity - no doubt about performance gains, but even in OEM they just don't seem reliable.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
