f**k the radials of for a start..lol, i can see you forever chasing you ass with those things..and breaking shit..
i'll take a 2WD skyline with slicks any day of the week over a GTR, i think it is much easier to get them to e.t
and hook up with a laggy turbo
cheers
darren
Why the hate for radials?
Iv been trying to work out what tires to get for my stock rears for drag, and was considering M/T's or Hoosier radials?
Why do you suggest slicks (assuming racing) for drags?
I will be taking my 32 gtst to the track in near future with some were around 350rwkw totaly stripped but has cage only thing that wont be going for it is ive got 4.08 in it for drift has s15 rear cradle will go out with some stock sus in the back. see what we can get it to do would love and 11
ive done 11 in R32 gts with 430whp and M/T. No changes apart from coilovers (damper as soft as they go)
im sure i can get hold of some whats the idea of front i always thought was only rear mattered
You wont get the weight transfer your looking for...
Dial up zero camber at ride height and a slight toe in down back.
they absorb f**kloads more shock, they are a lot easier to get to work without suspension mods
you will go faster and break less shit(driveshafts/tailshafts etc)
people that go fast on manual trans with drag radials deserve a big pat on the back, it ain't that easy...
i don't hate them, they serve a purpose, i only use them for the street, but even then i like bias plys..but they don't go around a corner..lol
cheers
darren
Edited by jet_r31
^^ that's crazy talk. You gotta spend mega bucks, to get a 2wd car to hook up any where near as good as a factory gtr.
dunno, if your talking slicks on a 2wd and streeters on a gtr..ill take the 2wd, guess there many ways to look at it though, not sure which angle
you are coming from
cheers
darren
Ok so here's the parts we have so far...
an r33..good compression..auto with shift kit...To4z turbo..750cc injecotrs and tomei intake pump..either an emanage or an adaptronic ecu...diff will be welded...and we have pineapples for the rear end....
If we get some slicks we should be close yeah? Any recommendations for 16 inch slicks..what size can we fit under there?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
