Yeah I was skeptical about the diff as well, but not having had any experience with FWDs I thought id give it a go, and boy did it make a difference; like night and day.
The control coilovers are quite soft so the car loved to bake the inside wheel on exits out of tight corners no matter what I did. With a welded diff you are able to use the power to pull the car around the corner, its truly incredible. The fact that its welded doesnt even really affect entry so long as the suspension is set up right with driving style to suit.
I could have fitted an LSD ($1000+ from US) but for the money I dont think I need to try it, and the car is already fast. Welding the diff was worth over 2 seconds at Winton with nothing else done.
Do they weld diffs in Excels too?
So the weekend went good , I had a blast! Got nails hard in the rear. Bloke behind me had no brakes at the end of the straight at Symons plains his left brake nipple wasn't right and this was the end result,post-134876-14409273236901_thumb.jpg
But if bad luck but it's all good I guess that's racing, bring on the next round [emoji106]
That sucks. Id be pretty annoyed if someone did that to my car - thats bad racing imo. And wont be cheap as you cant just unbolt the rear quarter to put another one on!
Each driver has a responsibility to race safely, but obviously staying close to you to try and pick up a position was more important to him and as a result plowed into you.
It is however an entry level category like PC so its no surprise :-(
  • Like 1
i know a few people in the pulsar challenge, put up a pic of your car matt!
its interesting that most people opt for N14's due to price and independent rear suspension, but often the top of the field are N15's. bit of tweaking to the beam and they handle well.
and yeah, lots of people saying good things about the welded diffs. Mfactory release a helical diff last year which is around $700usd and the other option is discontinued Nismo which can fetch around $1500 secondhand
anyone here running in Pulsar Challenge?
Apparently you can build one for around $5000 and race meets should set you back around $500 a round. was thinking of splitting the cost with a mate and running the enduros with him.
keen to hear people's experience with them!
Damn... that's actually really cheap. Way, way cheaper than I thought. I need to look into this!
edit: apparently you can bore out the engines and such. that would tend to increase the cost, lol. what % of competitors have done this ? how do they enforce some of the other restrictions on internals?
Edited by Skepticism
What? You sure? Very little modification is allowed.
Correct.
Only standard rebuild tolerance is accepted. You can bore 0.6mm out the block.
You can take 0.25mm off the head. But the compression has to be with a specified range.
It's all in the regs.
  • Like 2
  • 2 months later...
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
