I thought I'd start this thread up partly to show what we are doing in our build, but also to get some idea's and advice from the many smart people on here along the way.
The car itself is one of the original handful 2007 JDM GT-R's.
The car was purchased brand new by Russ (giant) in Japan late 2007 and shipped to Australia where it was originally set-up for Tarmac Rallies. Cage, race seats, custom cat back exhaust, Works Bell shifters and the early Cobb system. It was only raced a couple of times and then it basically ended up in a shed collecting dust.
You can see Russ' initial build thread here: http://www.skylinesaustralia.com/forums/topic/233474-r35-prep-for-rally-tas/
I've since purchased the car from Russ in this state and initially was planning on doing Targa in it. However I've since change my mind and am now working towards building it into a circuit racing car for our local Production Sports series which will pit me against cars such as Porsche Cup GT3 cars and other older GT series cars (Moslers, Ferrari 360 Challenge and 430GT etc). The main races themselves will be 1hr timed events.
We are limited with the mods we can do. Engine must remain 3.8L but is otherwise free (free means we can do what we like in terms of allowed mods). Turbo's must remain factory spec, exhaust is free from turbo back, suspension is free, brakes are free, gearbox is free, panels / aero are free of construction type but must remain factory in shape.
We can run slicks but wheel widths must not exceed more than 44" in total. (So could run 18 x 11 square in theory).
The engine when I got the car was pretty fubar (had been broken and repaired badly mostly due to a lack of parts back then) so we now have a stock new motor in the car. We will look at pulling down the old motor soon and building it up.
The original gearbox had also been broken and repaired badly so this has now also been replaced with a brand new but stock 2012 gearbox.
We have also now updated the Cobb with TSM software and are using an SD tune (just pump 98 for now but will be running race 105 in the future).
Replaced the exhaust with an Acrapovic system, dodson dump pipes and DBA spec turbo inlet pipes.
Updated the turbo's with genuine IHI specV cores.
Custom AMS intercooler piping.
HKS fuel pumps.
HKS Trans cooler
421199_10150751130157564_1775336748_n.jp
We've put in KW 3 Way competition shocks, dodson front upper arms and hardrace arms on the rear of the car. We've also put in Whiteline swaybars. We've also upgraded the wheel studs to ARP's to deal with the extra loads applied by slicks.
945419_10151916649742564_2135079761_n.jp
Panels so far we have oem spec carbon bonnet, boot, wing, front guards and side skirts. We will be getting molds made shortly to make up some fiberglass doors and lexen windows. I'll put up details of that when it's done. Current weight sits at 1700kgs with the aim of getting the car to under 1600kgs.
We've also had to custom fabricate up some mounts for the Aerocatch bonnet latches and a rear tow point (since they weren't standard in 2007)
There's still plenty more to be done before it's first race in July so I will try and keep this updated as we go along. The main focus over the next few weeks is set-up and engine and brake temps and seeing what if anything extra we will need to do to look after them. Any thoughts on this is welcome! We are only running 15psi currently whilst we only have the stock motor / gearbox in the car so power is well down on what we know we can make. But here's the car as it sits right now after it's first shake down run a few weeks ago.
923032_10151882508602564_1035673296_n.jp
https://www.sau.com.au/forums/topic/425308-snowys-production-sports-r35/
  • 3 weeks later...
First event is July 19-21 @ Sandown as part of the VSCRC Sports Cars round.
Car is currently off at Jenny Craigs to get light-weight doors and lexan window's made up.
Local company Raceglass is making them up as I've decided to go the fiberglass route rather than full carbon fiber spec as long term it may end up being a lot cheaper.
http://www.raceglass.com.au/
We've also recently added an Aeromotions R-static wing. Initial impressions were very good although I feel we have to improve the down-force at the front now especially in higher speed corners where I was starting to get a fair bit of front end wash-out. But Aeromotions have done a fair bit of development with this wing specifically on the R35 and the instability I felt at the rear of the car at PI was definitely gone.
  • 3 weeks later...
Some small updates.
Rear diff cooler has been installed.
Have also got a brake water spray kit to help with the brake temp issues. We also have some extra brake cooling ducts being fabricated which I will post up when they are done. But for now this is the kit ready to be installed.
Finally in a bid to shed some weight we have decided that instead of putting on some light weight doors and windows we'd just completely remove them!
1013978_10151997529372564_510343772_n.jp
  • Like 1
Good to see an R35 giving a proper shot at racing, the targa spec ones have not been competitive.
Will it be your first race in about 3 weeks or have you done some racing before. There's nothing quite like sitting on the grid waiting for the lights to go out...
Either way, Good luck!
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
