Hi guys
Trying to understand power and top speeds at various race tracks. I know there are a heap of variables but i'm doing this just to get a general idea.
What would be useful is car, weight, power (kw at the wheels or estimate) and aero. Yes, other things like gearbox (sequential vs H pattern), gearing and traction come into it but, like I said, i'm just after estimates.
Ideally your speed will be via a gps system rather than a quick glimpse at the dash.
I'll start...
Car: 33 GTR
Weight: 1650kg fuelled with driver.
Power: 450awkw (claimed)
Aero: standard
Wakefield: 214kmh
Eastern Creek: 245
Mt Panorama: 272 but backed off very early cause i'm weak.
Add what ever tracks you've raced at.
I'm predicting that my speeds are low for the power level, but we'll see.
Edited by tk80
https://www.sau.com.au/forums/topic/425745-top-speed-circuit-vs-power/
The biggest factor in top speed is power, when comparing similar. Aero differences from different wings, whether you have the windows down, etc will play a small part as well. Grip levels will play a small part also as it determines how early you can get on the gas. Car weight and wheel weight also plays a part, as does tyre width. Skinnier tyres with a higher grip level will out perform wider tyres with lower grip, because wider tyres create more rolling resistance.
Your mid and exit corner speed out of the last corner onto the straight plays a major part in your terminal speed at the end of the straight, I have about 110kW atw in the Speads, but I'll hit 260+ at the end of the main straight at PI due to coming off of the last corner well.
R33 GTST,
350 rwhp,
Home made front splitter & Gt wing
Lakeside 57.6 sec
232 kph into carousel
217 kph into hungry.
F, 245/45/17 FZ201
R, 255/40/17 FZ201
QSTAR/Race chrono.
big speeds Noddy!
obviously got alot more power now than whenever we've been on the track together!
Only about 50hp, most gains have been in aero and suspension. These federals have such woweful grip i have put a lot of time into setup. LOTS OF TIME. As a result, mid corner speed os up 10-15 kph at carousel, hungry and estern loop. So looking forward to the new motor and better tyres.
I have a little ae86 levin out of Japan. Ex TRD cup car, its only got 150 rwhp, 920kg wet with driver, punching out 60.8 sec. Its na1600 on webbers 225/50/15 V70A. Such a fin car to drive. Changing gears @ 8500-9200 rpm...ind bending.
Edited by Noddy
got a video or link to the results Stuart?
Car: 180SX
Weight: 1360kg incl driver
Power: 200rwkw (claimed by previous owner when i bought it)
Aero: none
Box: stock H Pattern
diff : 4.3 shimmed viscous LSD
Tyres: Federal FZ201
Lakeside: 205.5km/h
Time: 59.6 (05/04/2012 on Natsoft and QR's 2012 midweek sprint results)
link to video or results for that too please :)
S15 so not directly comparable.
Car: s15 200sx
Weight: 1150kg without driver
Power: 265rwkw
Aero: wing and front splitter
Wakefield: 199km/h (via data logger but that is with my foot still completely flat to the floor at the kink)
Eastern Creek: 228km/h
1.04.0 at Wakefield
1.39.6 at Eastern creek
Have a new engine in the car now that is yet to go to the track.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
