Hi guys
Trying to understand power and top speeds at various race tracks. I know there are a heap of variables but i'm doing this just to get a general idea.
What would be useful is car, weight, power (kw at the wheels or estimate) and aero. Yes, other things like gearbox (sequential vs H pattern), gearing and traction come into it but, like I said, i'm just after estimates.
Ideally your speed will be via a gps system rather than a quick glimpse at the dash.
I'll start...
Car: 33 GTR
Weight: 1650kg fuelled with driver.
Power: 450awkw (claimed)
Aero: standard
Wakefield: 214kmh
Eastern Creek: 245
Mt Panorama: 272 but backed off very early cause i'm weak.
Add what ever tracks you've raced at.
I'm predicting that my speeds are low for the power level, but we'll see.
Edited by tk80
https://www.sau.com.au/forums/topic/425745-top-speed-circuit-vs-power/
The biggest factor in top speed is power, when comparing similar. Aero differences from different wings, whether you have the windows down, etc will play a small part as well. Grip levels will play a small part also as it determines how early you can get on the gas. Car weight and wheel weight also plays a part, as does tyre width. Skinnier tyres with a higher grip level will out perform wider tyres with lower grip, because wider tyres create more rolling resistance.
Your mid and exit corner speed out of the last corner onto the straight plays a major part in your terminal speed at the end of the straight, I have about 110kW atw in the Speads, but I'll hit 260+ at the end of the main straight at PI due to coming off of the last corner well.
R33 GTST,
350 rwhp,
Home made front splitter & Gt wing
Lakeside 57.6 sec
232 kph into carousel
217 kph into hungry.
F, 245/45/17 FZ201
R, 255/40/17 FZ201
QSTAR/Race chrono.
big speeds Noddy!
obviously got alot more power now than whenever we've been on the track together!
Only about 50hp, most gains have been in aero and suspension. These federals have such woweful grip i have put a lot of time into setup. LOTS OF TIME. As a result, mid corner speed os up 10-15 kph at carousel, hungry and estern loop. So looking forward to the new motor and better tyres.
I have a little ae86 levin out of Japan. Ex TRD cup car, its only got 150 rwhp, 920kg wet with driver, punching out 60.8 sec. Its na1600 on webbers 225/50/15 V70A. Such a fin car to drive. Changing gears @ 8500-9200 rpm...ind bending.
Edited by Noddy
got a video or link to the results Stuart?
Car: 180SX
Weight: 1360kg incl driver
Power: 200rwkw (claimed by previous owner when i bought it)
Aero: none
Box: stock H Pattern
diff : 4.3 shimmed viscous LSD
Tyres: Federal FZ201
Lakeside: 205.5km/h
Time: 59.6 (05/04/2012 on Natsoft and QR's 2012 midweek sprint results)
link to video or results for that too please :)
S15 so not directly comparable.
Car: s15 200sx
Weight: 1150kg without driver
Power: 265rwkw
Aero: wing and front splitter
Wakefield: 199km/h (via data logger but that is with my foot still completely flat to the floor at the kink)
Eastern Creek: 228km/h
1.04.0 at Wakefield
1.39.6 at Eastern creek
Have a new engine in the car now that is yet to go to the track.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
