Which fuel do you use??
Shell Optimax...
Regular unleaded = 390kms
Optimax = 460kms + 8c/litre more
$44 - to fill with reg
$49 - to fill with opti
obviously depending on when i fill up as to what the price is.
Guest zerorespect
so does anybody really know what is the best to use....?
i've been hearing horror stories of late regarding optimax fouling plugs with the "cleaning" additives in bikes...someone was trying to tell me the same thing was happening in wrxs
i've switched across from optimax to synergy..given that work will only give me a fuel card for mobil and/or shell the choice is kinda limited...?
is bp any good...i thought they were like light years behind the other guys...?
hmmmm... if there was a mobil near me id probably use it after hearing about the probs opti causes... but then again ive used it for years without a problem on my old crap box.
regular unleaded (go the fuel requirements of a GTS!!!) but only from BP, Mobil, Caltex or Shell (the last 2 get their fuel from the same refineries anyway) gets me ~450km on a full tank.
Hate wooly's/safeway (bloody vic names) fuel with a passion coz its always watered down. Same with some independants, I'll only ever use em if I'm either short on change or they have a really mad price on fuel (like 10c lower)
When I used to have the 180sx I was partial to Synergy, and I got really good results using it with mobil's synthetic oils n additives. I think its better that way, coz its all from the same company, and from experience as long as you keep things uniform there's no problems, there's only trouble when you start mix n matching (yes I'm a techsupport person who hates ppl who buy hardware that's obviously incompatible with their PC's)
  • 1 year later...
I have fuel cards for mobil and bp, which is good because i've heard optimax is rated between 95-98, where as synergy 8000 and bp ultimate are actually 98ron?
I will use either bp ult or syn8000, mainly mobil around where i live so thats what gets used mainly.
i have a bp with ultimate right down the road... so i go there.
i used to used optimax, but last service they asked me what fuel i was using because my fuel filter was reasonably dirty. I thought nothing of it.
But hey, BP is right down the road now, and im lazy.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
