:thumbsup:
Sneaky edit :yes:
Just got home up and opened one of the parcels waiting for me, this thing is pretty big haha
Yum :cheers:
Pretty sure it's a twin scroll Super94 HTA :)
So, how much work is lined up to be done before this thing comes to life and finds a dyno?
:banana:
Hey XKLABA, are you running a HTA turbo in your GTR? How did Scott from Insight like it?
I had my 34 tuned by him, can't wait to take it back once all the upgrades are in
Nah, twin GT-RSs
How good is Scott as a tuner :)
I am looking into an upgrade ATM and one of the crazy ideas I'm having is twin 3071s using the GT-RS from cover, just sorting out the rears, Kando have a T25 GT30 rear housing for a 90 trim so its a matter of seeing if it can be machined to fit and made to go into the factory location
Sneaky edit :yes:
:D that's how I roll
Twin HKS GT-RS's.
Edit. Beat me to it lol
Yeah its the super 94 twin scroll, the motor should be nearly finished by lewis maybe 2 more weeks then shipped to gold coast to be fitted and a run in tune so should be running within a month but I work away so its a pain in the ass trying to organize stuff but getting closer now, heres some more hta porn
Looks the business! It's really going to look tough in there, and that's not even touching on the insanity it's capable of creating. Your car really really is going to be a complete monster, soon. Nice work.
Nah, twin GT-RSs
My GTRS recently decided to die on me :(
Planning on getting it rebuilt to get me through the next few months of events then the car comes off the road for some major work :D
Scott is a great tuner, he did a very nice job with the 34. I hit a few limitations with the car and Scott made it a safe tune with still getting nice results
My mechanic is very pleased with Scott's work as well and is sending any car that he works on to him
That is a crazy idea lol
Nah, twin GT-RSs
That could be quite an interesting combination. If you are exploring that kind of idea - why not see if twin GTX3067Rs can be made up, using the 90 trim turbine?
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
