awesome progress mate, bet you must be chomping at the bit for a drive by now :)
Hanging to drive it, but its first outing next week ill be flying interstate for a few days so dean and Brett will have to text me the results.
Front upper suspension nismo
I'd suggest talking to John from UAS about his custom upper control arms that prevent binding throughout suspension movement.
Here is a link: http://www.uniqueautosports.com.au/Parts-Shop/uas-pivot-bearing-adjustable-top-control-arms-564.aspx
I would support Russell's comments on these upper suspension arms as they are a good piece of kit.
When the top arm moves through the suspension travel range the top arm attempts to twist which it cannot normally do and instead it chops out you top arm bushes. This design has a pivot point in the middle of the arm which allows rotation reducing friction and saving your bushes from damage.
To test this if you take the spring out of your front coil over and push the suspension up through the travel range you will feel the friction as the suspension attempts to twist the top arm. With these UAS arms in place the suspension movement has this friction removed because the top arm can twist on the pivot point as it moves up through the suspension travel range.
Or just replace the Nissan inner upper arm mount with a Nismo one and the problem goes away.
I just had a look at the Nismo mounts (in a kit) and they are about the same money if not more than the UAS arms and the Nismo kit still isn't going to give as much camber as you actually want even with the extended LCA's.
Mind you I have the UAS arms and also want the Nismo mounts and LCA's... Just too expensive to justify at the moment
  • Like 1
Well the Nismo mounts are really just standard mounts with relocated holes for the arm to bolt into. So if you want to do what half the race cars have on them and relocate the holes there isnt much stopping you from butchering a stock bracket. The LCA is a different story, obviously. Someone has a set of LCA's & Nismo castor rods for $500. From memory the LCA gives you +5mm. Either Bri73y or stevena were selling them. Anyway you go fast enough so stop scaring the WASCC beards.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
