awesome progress mate, bet you must be chomping at the bit for a drive by now :)
Hanging to drive it, but its first outing next week ill be flying interstate for a few days so dean and Brett will have to text me the results.
Front upper suspension nismo
I'd suggest talking to John from UAS about his custom upper control arms that prevent binding throughout suspension movement.
Here is a link: http://www.uniqueautosports.com.au/Parts-Shop/uas-pivot-bearing-adjustable-top-control-arms-564.aspx
I would support Russell's comments on these upper suspension arms as they are a good piece of kit.
When the top arm moves through the suspension travel range the top arm attempts to twist which it cannot normally do and instead it chops out you top arm bushes. This design has a pivot point in the middle of the arm which allows rotation reducing friction and saving your bushes from damage.
To test this if you take the spring out of your front coil over and push the suspension up through the travel range you will feel the friction as the suspension attempts to twist the top arm. With these UAS arms in place the suspension movement has this friction removed because the top arm can twist on the pivot point as it moves up through the suspension travel range.
Or just replace the Nissan inner upper arm mount with a Nismo one and the problem goes away.
I just had a look at the Nismo mounts (in a kit) and they are about the same money if not more than the UAS arms and the Nismo kit still isn't going to give as much camber as you actually want even with the extended LCA's.
Mind you I have the UAS arms and also want the Nismo mounts and LCA's... Just too expensive to justify at the moment
  • Like 1
Well the Nismo mounts are really just standard mounts with relocated holes for the arm to bolt into. So if you want to do what half the race cars have on them and relocate the holes there isnt much stopping you from butchering a stock bracket. The LCA is a different story, obviously. Someone has a set of LCA's & Nismo castor rods for $500. From memory the LCA gives you +5mm. Either Bri73y or stevena were selling them. Anyway you go fast enough so stop scaring the WASCC beards.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
