Hi All, Own a R32 GTR
I've currently got 2.5" Inch Dumps to 2.5" Front Pipes to a 100cell then true 3" Right back. ( Currently on stock turbos )
My new setup that will be completed this year will be
HKS GT-SS
Haltech Pro
Tomei Cam gears
Tomei Pon Cams type b
Arp Head studs
Tomei Metal Headgasket 1.0mm
Id1000s
Tomei Valve Springs.
E85 & 98 Tune.
Looking around 350awkw hopefully or there abouts... Now is it worth me going a new exhaust.? Will i be restricted by this exhaust?
I'm thinking of going 3" Dumps to 3" Splits to 100cell then 3.5" Right back but i dont want to lose my down low response.
By upgrading the size a little will it be even noticeable response difference?
Getting so many different opinions id love to see some dynos before and after exhausts if they could display for me?
Thanks all.
https://www.sau.com.au/forums/topic/426415-exhaust-advice-r32-gtr-twins/
Before my 32 GTR went in to have work done, it was making 320awkw and it had 2.5" dumps and fronts, metal cat and 3" cat back.
So 350awkw shouldnt be a problem.
Thanks for the input, do you mind saying what turbos u had / lil setup like i did ? was this on 98? how much boost?
thanks again
I had stock dumps, put on Tomei dumps - no difference, only change was exhaust and a lighter bank balance.
There was no bottom end loss, no top end gain (PULP/340rwkw). Only difference here is E85 - would potentially offer benefit, necessity? Certainly not.
with bigger dumps, your gona loose some bottom end response it's inevitable, but slightly more top end power
Proof?
We have just had a discussion about this small exhaust vs big exhaust bizzo only last week week. The guys that have gone from a peanut exhaust to something big and free flowing have ALL SAID the bottom end felt stronger! Myself included.
Including Nisomid? Who just SAID 5 MINUTES AGO it makes absolutely FA difference both top end and response, so the placebo of the better exhaust sound has gotten the better of u .
I've known people to revert back to smaller front pipes on sr20 to get better response to response for drifting so I assumed dump pipe/s would be the same.
And people said when they put on a bigger exhaust they lost some low end response but made up for it in top end power. So If u think more free flowing the better, then why don't u put on a 5 or 6" exhaust" ? you'll be the fastest car on the dyno in the world then
Sultanaz, Your existing will be fine for your goal and moar (400+kws). Save your dollars for something else.
My setup is similar to yours except I run -7's. 330awkws @ 19psi, 98ron
Haltech Pro, Type B, ID1000's, 3inch blitz Nur spec exhaust, Xforce dumps, 100cell cat
I wish I made the power as easy as you Sinista.
I'm running -7's on E85. 325rwkw @ 20psi. HKS dumps, unknown front pipe, 3" 100 cell cat and 3" cat back.
I'm still running standard actuators though so I think that might be holding me back as the boost drops off to 16psi.
Eventually I'll go up to a 3.5" exhaust to see what happens.
  • Like 1
Yeah mate,
Had Trust T517Z twin low mounts (pretty sure 10cm)
Remapped standard ecu
Adjustable cams gears
Tomei Poncams Type B
Head had slight work done
Nismo 660cc injectors
HKS 2.5" dumps
Unknown 2.5" to 3" front pipe
100 cell cat
unknown 3" cat back with twin mufflers (nice and quiet, barely hear it idle)
All running 20psi on 98ron
"It's inevitable you will loose bottom end"
Ash didn't, yet went bigger. Maybe that's how his car was setup. He DEFINATELY didn't go backwards as you're implying. Time to put the text book away and go off the guys who have spent the money trying different things AND have the numbers to prove.
Ill give you an example. My GT RS setup with a kakimoto "full mega N1" exhaust (which had a 2.5 inch restrictor in the rear muffler) was terrible. At 2.0 bar it made 414, 1.7 it made 404 or something. Got rid of that catback to a 3.5 inch and not only did it woke up the turbos but it also went alot better uptop. Then went to smaller turbos with a twin 3 inch and I made AN EXTRA 100 kw at 4000 rpm and an extra 25 ontop which is still no where near it sits today! Real world experience, real cars. Not something you have read between session on red tube!
OP. As Allan said, 34 dumps/sole sort of bellmouth jap dump, find a front pipe which is twin 75's into 90 (I think midori do a set), big cat and ATLEAST 3.5 inch cat back. Without some silly restrictor like alot of the "brand name jap" exhausts have. Having been through it a few times it really isn't that mug more to get a custom system made up which hugs the car with big meaty mufflers. If I had to do it again, that's what I would do!
He makes 475kw out of low mount turbos and makes power pretty much from idle, so I think he has a bit of an idea about an exhaust that works!
↑↑↑ THIS! Piggaz car is faarkin mental in everyway the setup is nothing short of amazing! So I suggest a lil more research pumpkinhead ;) Piggaz knows his shit! Clearly you dont!
BOOM!
BOOM!
These setups look like a recipe for a response burger with the lot! MMM i'll have all I can eat thanks
He DEFINITELY didn't GAIN power which is what your implying! I was talking about the dump pipes not the cat back, so don't let the cat out of the bag
and Ash doesn't is what he's saying?
wow talk about humping the shit out of someones leg there, and this is coming from the guy who tries to sell his r33 for 19k$ I mean but I gota give u cred if u sold it then it certainly would of been the scam of the century dats 4 sure. I've sold more cars then you've got hairs on you're ass and theres no way in a million years u could get 20grand for an r33gtst, I mean r u serious?
Even r33 GTRs can get cheaper then that, and r34gtt neos r certainly way cheaper, so I suggest u do a little more research on the car value market b4 tryin to pull a fast one and or waiting 10 years b4 someone gave u 19k
Sometimes I wish I could bulldog this guy. Bulldog IRL. he walks through the door, then BAM!! Bulldog to the face.
LMAO what tuff guy fail, whats a bulldog? I've never heard of the UFC move b4, or is that KFC..
Edited by discoPumpkin
So want to post a bulldog, but may lead to permaban lol. No threat of physical harm here darling. If you fcuked me off you'd know. Just kinda getting sick of the merry go round your on. People are getting ill informed by a keyboard warrior who has an ego issue and doesn't know when to stop flapping his gums. Show me your real world data to prove all the Indy car teams, all the competitive race teams the world over, and all the guys here with real life experience, wrong. Maybe then we will all go throw twin 1 3/4" exhausts on our gtr's.
I seriously think I've had smarter farts than you have had thoughts in your entire pointless existence in this world.
Hugs and kisses, Allan
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
