What Is 'too Much' Power For The Street?
74 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
no 500kw car is going to be convenient or street friendly on a daily basis..and the price of fuel and wear and tear will soon have you buying a barina to get to work in....
doesnt mean it cant be done though, but even a 300kw car isnt always great on a daily basis...there are far more comfortable ways to get around...
Would I not drive on a street a 458, GT2, Veyron, Koeniggseg, Aventador? How much power do they have? Why would I not then drive a big HP GTR on a street just because my budget is lower?
Now what street are we talking about?
Now Mr Willis's private 'street' up on the Central Coast looks the goods.
According to JEM's latest Lambo tests they come from factory with bugger all..... Twin turbos should soon rectify that!
300 odd rwkw is getting closer to 'enough' for the street.
Would not go any bigger on a cam than what I have for a manual and regular street driving, too much overlap = a prick to drive smoothly through lower gears. Stalled auto = no problems.
I'd say the upper limit would be where you can't start opening it up without losing traction - tyre choice, suspension of course play a big part in it.
Same with big turboed imports - my old R32 was laggy and it sucked balls unless wringing its neck. 4.3:1 diffs did help with that though.
All depends on the car.. A 400rwkw Silvia is alot more silly than a 400awkw GTR.
Perfect daily street car would be a mild low 300kw GTR (-7s or -9s). Standard looking engine bay, relatively reliable, mid - high 11s quater mile on street tyres and not all that expensive to build. Once you wind up the power things tend to go bang..
In saying that low 300's does get boring :rofl:
Sif high 11s with them mods, i did that time on stock turbos and stock ecu ! 234kw
I hope to run a high 10 with that setup :yes: :yes: :yes: :yes: :yes: :yes:
Edited by sultanaz
My 26 GTS4 with 280 odd kw is more then enough on the street - to the point were i haven't even touched the high boost setting
Mind you its running RWD at current so i take it half easy - and is the first Forced Induction car i have driven so of course it feels quick to me
The power im getting used to it....
Hard question to answer but id say even 200kw is more then enough
Boost level and power level is still all controlled by the right foot :P
I agree with that for sure and just because a car is 300, 400 or 500kw that does not mean it has to be driven as such
i think better wording then "Too much" is usable
Yep, its the good thing about modern turbo cars :yes: Can be driven daily without knowing its got big power! Mine is smooth as on the street, its only the idle that gives it away now!
I hear you brother! the straight exhaust with single hooker muffler can be quite loud haha
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
