I wasn't talking about the v8s torque curve, I was talking about people back then knew that larger duration cams will cause peak power to arrive later in the rev range, the same will happen with a modern import and it doesn't matter if you jump up and down, squeal, pray, beg. that's what's gonna happen
You guys talk as if it takes 5 mins for -5s to spool up well it doesnt, and for those 2 corners on a track where this scenario happens your right but for the the rest of the track a stock gtr will get slaughtered everything else being equal.
About the revving i was just saying, but change gears at 7k and -5 will still be on song.
Changing gears at 8k is not the issue, its when you hold it there around corners things go pop.
I think the Group A cars were limited to 7k as part of the regulations to give the V8s a chance....correct me if I am wrong.
off
The 7k limit was to reduce excessive engine wear
I track both my stock cam stock turbo R32 GTR and my -7 type R poncam R34 GTR, the 34 has better tyres suspension and brakes and making 60 rwkw more and with the extra lag it's just under 2 secs slower around Wakefield, can only imagine how bad it would be if the boost came on a 4k
During 1992 the R32 was ballasted to increase the homologated race weight, and max boost was reduced, enforced by a CAMS/FIA relief valve fitted to the plenum. Bit of a precursor to today's performance parity measures.
Got a chance to talk to Fred Gibson a few weeks ago, he said they ran them up to 8500rpm. They were making 680bhp. Dont know where the 7k thing came from.
That's interesting, I'll have to remember where I heard that, I've based my builds off it so I don't have to run past 7-7.5rpm
I'm sure it was when I was helping the BSM guys
There were a few other things they did after the weight was increased and boost level limited . I will ask but I think one was increasing the static CR but can't remember the other . They didn't get all the power back but enough to reduce the loss .
A .
Is that the same scenario at higher speed tracks
They tuned the engine with pressure transducers to do cylinder pressure over crank degrees. On 1.3 bar they went from 550 back to 670bhp. They nearly got it all back.
Very clever stuff.
Very clever stuff.
Didn't they use that weight penalty to improve their suspension and chasis too?
I never got a clean run at EC in the 34, but the 34 was 9 secs off the 32 with what it did get
The most time is lost through corners, better exit speed/acceleration means more/higher speed you have along the straight
9 secs a lap slower!! Something else must be going on there. Can't believe a -5 cammed GTR with better suspension and tyres is going to be that far behind. How can this be??
It's not, it's -7.
Like I said I never got a clear lap in the 34, the 32 on the other hand I got EC to myself for a whole day and lots of lapping was involved as well as two tank fulls
The 32 is just a bulldog of a car with instant useable boost any where over 2000rpm and no down time in boost between gears, a prime example of what happens we you get a mix of parts that work together
Even the fastest track has a few tight corners, EC it's 2-9-11, with 4-5-6/7 slowing you down, all of which show lag for what it is
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
