For a daily with a boot and back seat either 2/4 door 34 turbo. If you want to mod for loads of power and only ever want one passenger and nt doing shopping or anything then Supra. Dont get me wrong you can get power out of the NEO but all depends what your idea of loads of power is. 300rwkw is a lot for a rwd daily and can be had with the NEO engine.
https://www.sau.com.au/forums/topic/426786-r34-or-supra/#findComment-6887021
The NEO loves power! Back in the day 300kw was pushing the internals blah blah but nowadays 400kw can be had on stock internals.... I got close and the car gets punished! Stock engine, stock headgasket!
Agree the supra is just ugly!
https://www.sau.com.au/forums/topic/426786-r34-or-supra/#findComment-6887027
Totally different cars!
Supra,
Pros - Beautiful looking outside, great engine.
Cons - SHIT interior, No backseat, no boot, impractical for daily if those are needed
Skyline
Pros - carry more then 1 other person, Decent Boot, Decent engine, just all round bigger
https://www.sau.com.au/forums/topic/426786-r34-or-supra/#findComment-6887054
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
