Many varied opinions, overall I think the chicks win. Both good cars the 34 is way more practical but I love Supras too. Cops may pick on you more in the Supra as looks to be going too fast even when parked.
Cheers, Grant.
hahah i notice there is never any pics of the interior of the supra! the worst looking interior ive ever seen!!!!!!!!
on a side not what wing is this 34 running?
Stock with different wing stands?
If you have high expectations expecting an interior from a jap import who made the interior cheap and tacky on purpose to keep costs low; you're gonna have a bad time. want a fancy interior and lots of space? get a toyota aristo :) same motor as the supra and just about as quick. Honestly you get a stupid amount of car for the price of them.
Fine... NSFW
http://vimeo.com/
add: 31515908 afterwards if you want boobies.
Man would smash that so hard.
that you know that makes me respect you a lot.
yes, would also smash.
N I personally don't think it was worth a warn. All I could see was black blobs :P
Aristo about as quick as a Supra?
Since when did the Aristo have as much success as the Supra did in JGTC ??? Oh wait it didn't even race in such a series.
And Supra has an amaziiiiiinggg interior, feels like you're in a jet fighter plane. Totally awesome.
thanks for everyone help, I actually went a different way and brought a v35.
"This is a CEFIRO!!!" (Tsuchiya negatively describing the performance of the V35 Skyline)
  • Like 1
I owned an R34 and a Supra at the same time a few years back. The supra was awesome to drive around when it was just me and my wife in the car. If we were taking anyone else, it would have to be the R34. At the end of the day, it all comes down to what you want to use the car for. Yes the stock internals in the Supra can handle more power, but if you are driving the car on the road as a daily, you wouldn't want that kind of power anyway. So, for a car to be good fun to drive that can be modded to decent power for daily use and still be practical, I would go for the R34.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
