i too am looking into getting tune done on my r33 gtr am running tomei reytec ecu. software is in english . has wideband and datalogging etc. any suggestions who has any experience with these ecus. i have put a run in tune myself , very easy to operate...
I'll need more than 1 to curb the depression!
More beers it will be then, Man that thing should be making close to what it is on E85 on pump fuel with the right tune.
Mine only has:
Unopened Engine
Apexi Power FC
CAI BOX with Pod
Yellow Jacket Coil Packs
Z32 AFM
3" Turbo back + High Flow Cat
660cc Injectors
Bosch 044 Pump
Hypergear SS1PU Turbo - 20psi peak fading to 17psi (I need to set it to hold boost @ 20psi then it will make 400, ran out of dyno money to dial in the EBC to hold pressure)
That is what got me the 377hp on 98.
Speaking of signing up will be as soon as my gtr lands !!! Wanted to know is there any other track days or happy laps events that happen other than the ones that are on the 2013 agenda as I work away from brisy and 90% of these days are on my days away with work which I am spewing about !?!?
Hey mate,
The calendar has grown to be more of a rough guide as to when events are. If we have our way, there should be a few more track days coming around. Our aim has been to have an event each week so that people, such as yourself, who can't make it to one can make it to something else. With timing on these things, it does come down to QR and when they can let us use the track but we have strived to have a happy laps sesh every 6 weeks. Usually, a few weeks before the end of the month, I will post up events for the upcoming month. All of these will be confirmed and good to go ahead, unless stated otherwise. We also go through a rundown of the upcoming events at the monthly meeting (first Wednesday of the month).
All in all, there is a lot more coming up than what is on the calendar. Keep an eye out and you will be impressed. ;)
Cheers,
Tony
Just had a look at all star tuning and performance, just from looking at his web page it's very impressive. Has anyone ever taken there car to mercury Motorsport or heard anything about them?
  • Like 1
There's a few bad reports about MM including mine in the R35 section, I would strongly advise you go see Gavin Woods at Labrador, a lot of guys use him including myself and he is well experienced with skylines, even GTR35's.
you can also use a Power FC and run E-flex, my car for example does and I havnt had any problems with it,
Tohmez run with what angry said about MM and I have asked the same question about tuners in brisy north side in particular and I am guna go see all star as isn't to far from me and highly recommended by many!
Tony thanks for the info on additional events got me more psyched again to enjoy the common interest with everyone on here that others without skylines don't get !!! Look forward to see everyone's machines and gain valuable advice !
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
