Unlike the RB20 & RB26, the RB25 engines use a BKR style plug not BCPR. Although in most situations these type plugs can be interchanged. If you want a long life plug than go with either a set of NGK BKR5EIX-11 Iridium IX or PFR5G-11 Platinum otherwise a set of BKR5E-11 or BKR5ES-11 copper core units will do the trick.
Why so cold?
The tip is actually denoted by the suffix i.e. E, ES, EIX... The prefix i.e. BKR, BCPR... refers to plug thread and body height.
and there is bugger all difference between bkr and bcpr in body size. both have same thread size and pretty much the same body size (I think the bkr is something like 2mm taller from memory)
  • 9 months later...
Just looked at a mates 32 as he is having detonation issues. First check was the plugs and coilpacks. He has NGK PFR6G 11. I haven't ever used these plugs in either of my RB's and was wondering if they are suitable. The engine is a pretty stock one with exhaust, fmic and stock everything else with standard boost. I always thought the .8 gapped plugs were best and have used BKR6E in both my RB's being a redtop HR31 20 and S2 25, I am changing to BCPR7ES as I am runing a bit more boost. I have a pic of my new plugs yet to go in compared to the ones I pulled out of his 20 to compare. He plans to get some splitfires anyway but wanted to cancel out the plugs as an issue.
Plugs rarely cause detonation unless they are too hot a heat range. His plugs look in reasonable shape. Detonation is usually caused by either running too lean or too much timing. Coils won't have anything to do with causing detonation. A misfire yes, but detonation no.
As for gap, the bigger the better. Standard gap is 1.1mm. You only need to reduce the gap when running much higher boost and/or the coils can't cope.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
