Hey guys and gals,
I have made the decision to change my cams... At the moment I have hks step 2 272's with 10.2 lift. I'm changing because I want more response down low on the track instead of having to keep the revs up between 5g and 9g.
So question is what cam size would you use? The head has had extensive work done, motor is fully built running -5's, running 98 octane and it's a 2.6. So I am after something that is going to match and make the most out of the engine and turbos for track use.
I'm open to any suggestions. Cheers
https://www.sau.com.au/forums/topic/428164-what-cams-would-you-choose/
  • Replies 63
I had 260 x 260 tomei cams, had the standard cams put back in, 355 rwkw with the 5s at around 7000 rpm and the car feels great to drive.
which 260s did you have ? would be awsome if you have before and after dyno charts to see the difference between the two cams ?
B type poncams, this was a fresh build at a new workshop, I would love to know myself.
What I did have was -10s with Poncams, Motec M800 at 25psi on Shell 100 octane for a disapointing 350awkw, soon after the engine shit it self.
New setup -5s with stock cams, in went my old power FC with Nismo AFM with just over 20psi on Shell 98 for 355rwkw and so much better to drive, the engine dosn't have to run as hard to make power.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
