But then you can't get the injectors out on a neo. leaking between runners wouldn't matter. Another pointless option would be to get a machine shop to machine the base of the plenum for individual rubber orings. Then you will save money on gskets :)
I would just get another manifold
Yeah I don't really want this to get overly complicated, its a massive PITA cause was hoping to get it tuned
Cars been jerky and had a constant miss for the last year, pretty sure this was the cause so just want to fix it once and for all so I can ram some boost down its throat. hmm, might get new lower half runners and new OEM gasket and torque to exact specs and see what happens, theres no room to get a torque wrench in there so will have to put together out of the car this time then bolt it to the head,
if it leaks again ill just torch the car .. lol
got myself another manifold and have taken the old one off,
Anyone have tips here to ensure a tight seal on both manifold to head and plenum to lower runners?
this new manifold has been powder coated so should I sand paper that off at the flanges to create sanded surface or does it not matter? want to do this right first time so to speak...
use any gasket goo or leave clean and just assemble?
picked up the OEM gaskets from the dealer today, asked the guys behind the counter and one guy said the manifold Is likely warped and to get it faced, the other guy said the OEM gasket wasn't designed for high boost and wouldn't handle more than 10psi and I should get a steel gasket made up..
Got me considering welding it or having some kind of steel spacer made up..
opinions??
took the manifold to the engineering shop and all the flanges are warped upto 0.5mm, and to have them faced is $480, that's for 3 facings
Is it normal to have this happen on an intake manifold, or maybe its meant to be like that and the rubber OEM gasket takes up the gaps?
maybe it was overheated, the old exhaust manifold was warped but that's bit different, wondering now wether the cylinder head along the flange would be warped too, will get these bits faced anyway..
Yeah that's what I thought, taking it too another mob tomorrow which have quoted 80-120 per flange, bought a second whole manifold few days ago and it too is warped, im going to stick with stock manifold because from reading forums it sounds like the most ideal design etc for a street car...
can anyone confirm, should I be using any gasket goo for the fitment or bone dry and clean?????? sounds like a silly question but this will be about my 4th time with this and its becoming a joke.. :)
You only need a very light coating on the gasket, Hylomar still relies on a flat surface. If the flange is that warped that the gasket squishes out one side you will continue to have issues I think.
You could possibly try gluing a few sheets of sand paper to a thick pane of glass and using that to flatten it out, may take a while but I have seen it work on heads before. (bush mechanic style)
  • Like 1
opinions??
10psi? really? I had 1.3bar going into the stock gasket, zero leaks..
if you're having this much issue, I believe you may have a warpped intake manifold as others have mentioned.
Hope you get it sorted soon aye? I know the feeling when shit doesn't go your way you just wanna burn the damn car :(
I tried scraping most of it off and still squeezed out, my old man suggested I just use the Hylomar and remove the gasket all together so im going to try that..
yeah it does have a very slight warp which the engineering shop said was hardly anything and that it must be how im bolting it up, will see how I go today bolting it up without the gasket altogether,
fingers crossed :/
But then you can't get the injectors out on a neo. leaking between runners wouldn't matter. Another pointless option would be to get a machine shop to machine the base of the plenum for individual rubber orings. Then you will save money on gskets :) I would just get another manifold
leaking between the runners would matter as the runner from one would be robbing the intake charge from the other, hence why the gasket seperates one runner from the other
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
