Sau Nsw Tech Night: Suspension & Steering @ Heasman 06/09/13
Gday Guys, My names Brad Heasman, thought id quickly introduce myself here before I meet all of you on Friday night.
I currently work in sales and marketing in our Bilstein department, but did 3 years as a mechanic in our workshop. Im 21, love nissans, and I own and race a Nissan s14 time attack car. (which you will see on Friday)
On the night we will be having a bbq, so when you arrive there will be some food and drinks here, We will have our Bilstein engineers here, our sales guys, and some of the workshop guys here for you to talk to, or ask any general questions while we eat.
Look forwed to meeting you all!
Hi Brad and welcome to Skylines Australia NSW.
My son Clinton and I have been experimenting with suspension components for a number of years now and have accumulated a collection of Buddy Club, Ohlin and Pedders shocks before we went down the Bilstein path. During this time we have received a degree of assistance and advice from your staff plus a number of components through this journey.
On our R33 GTS-T we started with PSS9's from a GTR with fabricated spacers due to the difference in shock length between GTR's and GTS-T's.
To reduce unsprung weight and clearance issues we then moved on to Eibach springs with Pedders top mount blocks that allowed the use of standard top hats instead of the HKS style which chop the bushes out in a very short time.
We then focused on the rear suspension and decided to install a completely refurbished GTR rear cradle to improve our drive train and allow the use of matching Bilstein PSS9 shocks.
Again we went down the path of Eibach springs with Pedders top mount blocks that allowed the use of standard top hats to reduce unsprung weight.
We have been very impressed with the quality of the Bilstein product and we a now working through what seems to be a never ending set up and adjustment adventure.
I hope that you and your staff can provide some advice with ride height changes and the impact on roll centre and roll couple pertcntage.
I would like to go to this but won't be able to get there until after 6:30pm. Will that be a problem?
Finally pulled my finger out and sent my SAU membership and payment through today. :)
last one said meet at 6, start at 6:30... it started at about 8.
you might miss food if you get their late
I'm confirmed. Leaving North Ryde 5:30pm travelling by car...hopefully no traffic catastrophes will see me there by 6:30pm. Pumped!
Happy to give a couple of people a lift back Chatswood way if required!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
