Squat
20kg x 10
40kg x 10
50kg x 10
50kg x 5
45kg x 30
45kg x 20
Pause Squat
40kg x 5
45kg x 2
Lat Pulldown
35kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 7
65kg x 4
Seated Row
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 5
Ab Crunches
150
150
10 min rowing machine
07/12/13
Bench Press
20kg x 10
30kg x 10
40kg x 6
45kg x 5
45kg x 4
Deadlift
50kg x 10
60kg x 10
70kg x 10
80kg x 5
85kg x 3
Captains Chair
10
10
10
10
10
10
10
10
10
10
Did some shoulder band work too
55 min cardio @500 calories
11/12/13
Deadlift
60kg x 10
70kg x 10
80kg x 6
90kg x 4
100kg x 1
100kg x 1
Bench Press
20kg x 10
30kg x 10
40kg x 6
45kg x 4
45kg x 3
45 Leg Press
80kg x 10
100kg x 10
120kg x 10
140kg x 10
160kg x 10
180kg x 10
200kg x 2
Captains Chair
30
30
20
20
20
Knee Raises
20
13/12/13
Squat
20kg x 10
40kg x 10
50kg x 20
55kg x 6
47.5kg x 5
47.5kg x 6
45kg x 10
Pause Squat
40kg x 5
45kg x 3
Single Leg Squat
30kg x 10
Lat Pulldown
35kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 4
Seated Row
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 8
Ab Crunches
250
250
150
Not a great session, very tired and also sore from physio.
Squat
20kg x 10
40kg x 10
50kg x 10
55kg x 10
60kg x 3
50kg x 8
45kg x 10
45kg x 10
Pause Squat
40kg x 6
45kg x 4
Single Leg Squat
35kg x 10
Lat Pulldown
35kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 5
65kg x 3
Captains Chair
20
20
20
Ab Crunches
250
250
45 min boxing @ 370 calories
Edited by L33SH
Nice squat improvement, hows the new pl gym? You going to change your program to something more that style or keep with the volume?
thanks, new gym is really good.
I have to change my program as some of my exercises such as seated row and leg press are not available at my new gym. I will still keep with the volume work but looking at adding some assistance exercises in for the 3 lifts which will not be volume based. My new gym loves the cables so probably start to add some cable work in.
Ah nice.
Your 35kgx10 single leg squat is that a pistol squat? If so that's an awesome effort, most people cant even do one.
25/12/13
Deadlift
62kg x 10
82kg x 6
102kg x 1
107kg x 1
82kg x 5
62kg x 15
Bench Press
22kg x 10
32kg x 10
42kg x 2
42kg x 2
Very disappointed in bench don't know why I'm going backwards and I don't know what to do instead of leg press or captains chair because they don't have them here.
Deadlift is looking good. Looks like I'm not the only weird one who'll be at a gym today haha
What about hanging leg raise? Do they have a pull up bar? Can't think of anything for leg press at the moment.
Yeah they have a pull up bar and Birds just suggested that too. I've left now but I'll do that instead next time.
30/12/13
Squat
20kg x 10
40kg x 10
50kg x 10
55kg x 10
60kg x 3
50kg x 10
45kg x 10
45kg x 10
Pause Squat
40kg x 6
50kg x 1
50kg x 2
Lat Pulldown
35kg x 10
40kg x 10
45kg x 10
50kg x 10
55kg x 10
60kg x 3
Captains Chair
30
30
20
20
T Bar Row
10kg x 10
10kg x 10
Single Leg Squat
40kg x 10
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
