I have the 4.3 ring and pinion if you want to try and wake up a few revs. I get what you mean about gear change but its definitely the less of the evils looking at how lazy it is out of Dandy and on to the straights. It looks lazier than my RB20 with a TD06
I have a 4.3 with a nismo 2 way in it. We have been using it up to date. But the 1.5 way provide much better turn in.
Lol..wow and its still that lazy. Are you still in the std manifild? Maybe if you want the power you need to get a better manifold in it.
I have gone 4.1 as it will give me better drive using 2nd and 17" tyre i run at places like Sandown and Winton.
Just to carify, it has the 4.11 1.5 way in it at the moment. However only for the last two Sandowns. Previous to that it had a 4.3 2 way for the last 18 months.
I do like the 4.3 ratio and punchiness out of the corners, but the 1.5 way turn in is amazing.
So a 4.3 1.5 way would be killer.
Well done in the shootout John! Very entertaining! :)
Was good to watch!!!!!!
Well done mate!!
great effort, you should be proud.
I reckon the Open and pro guys have you to thank for drying out the track :P
Nice drift
WTAC2015 by Erin Hourigan, on Flickr
Thanks everyone.
Finishing 4th in Club and fastest RWD in club. The car didn't have a huge amount left in it, we could have dipped into the 1.40's but that lap didn't come together.
Putting the 4.11 diff in the car was the wrong move, but we go on top of that early on Thursday in testing, changed back to the 4.3.
  • 3 weeks later...
Amazing work...huge crecit to you to be getting the results you do. You almost motivate me to get my car back out there but tired of being broke
Doesn't need massive HP, just be reliable. Worst thing is working on it more than driving it.
Yeh, my problem is my Skyline is still a road car and after 14 years of club/track work it had really taken its toll and so much of it was worn and need replacing. Woudl have bene easier to go and buy a neat std R32 and put my good gear in it and go dedicated track R32..but meh...when the R32 is back on the road it will be a tidy and reliable bus and hopefully a tad quicker than it used to be to boot
Yep learnt that one. Front mount plenum cost a lot of headache. Fabricator buggered my motor and it's never been the same since.
Just took out my motor with buggered bearings and about to put the replacement one in during the week.
Yes, less dicking around means less dicking around.
  • 1 month later...
Had the left side of the engine bay out over the weekend replacing the exhaust manifold gasket. Which had blown out 1,2 and 6 cyl.
However once we got the manifold off, we opted to change that as well. The one that was on there had never been swaped out, so 19yrs of service. The last 3 pretty much all track days. Another standard manifold has gone back on.
  • Like 1
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
