I have the 4.3 ring and pinion if you want to try and wake up a few revs. I get what you mean about gear change but its definitely the less of the evils looking at how lazy it is out of Dandy and on to the straights. It looks lazier than my RB20 with a TD06
I have a 4.3 with a nismo 2 way in it. We have been using it up to date. But the 1.5 way provide much better turn in.
Lol..wow and its still that lazy. Are you still in the std manifild? Maybe if you want the power you need to get a better manifold in it.
I have gone 4.1 as it will give me better drive using 2nd and 17" tyre i run at places like Sandown and Winton.
Just to carify, it has the 4.11 1.5 way in it at the moment. However only for the last two Sandowns. Previous to that it had a 4.3 2 way for the last 18 months.
I do like the 4.3 ratio and punchiness out of the corners, but the 1.5 way turn in is amazing.
So a 4.3 1.5 way would be killer.
Well done in the shootout John! Very entertaining! :)
Was good to watch!!!!!!
Well done mate!!
great effort, you should be proud.
I reckon the Open and pro guys have you to thank for drying out the track :P
Nice drift
WTAC2015 by Erin Hourigan, on Flickr
Thanks everyone.
Finishing 4th in Club and fastest RWD in club. The car didn't have a huge amount left in it, we could have dipped into the 1.40's but that lap didn't come together.
Putting the 4.11 diff in the car was the wrong move, but we go on top of that early on Thursday in testing, changed back to the 4.3.
  • 3 weeks later...
Amazing work...huge crecit to you to be getting the results you do. You almost motivate me to get my car back out there but tired of being broke
Doesn't need massive HP, just be reliable. Worst thing is working on it more than driving it.
Yeh, my problem is my Skyline is still a road car and after 14 years of club/track work it had really taken its toll and so much of it was worn and need replacing. Woudl have bene easier to go and buy a neat std R32 and put my good gear in it and go dedicated track R32..but meh...when the R32 is back on the road it will be a tidy and reliable bus and hopefully a tad quicker than it used to be to boot
Yep learnt that one. Front mount plenum cost a lot of headache. Fabricator buggered my motor and it's never been the same since.
Just took out my motor with buggered bearings and about to put the replacement one in during the week.
Yes, less dicking around means less dicking around.
  • 1 month later...
Had the left side of the engine bay out over the weekend replacing the exhaust manifold gasket. Which had blown out 1,2 and 6 cyl.
However once we got the manifold off, we opted to change that as well. The one that was on there had never been swaped out, so 19yrs of service. The last 3 pretty much all track days. Another standard manifold has gone back on.
  • Like 1
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
