Hi can anyone tell me if this mod works on the R32, Ive a 1990 GTS-t with the RB20det and an auto box running 10-11psi on full boost (according to aftermarket gauge) with full 3.5inch exhaust from the turbo including downpipe and de-cat and a pod filter. Sounds like a great mod but dont want to fry anything also is the solanoid in the same place on the R32. Thanx :banana:
R32 doesnt have dual stage boost... this is for RB25DET only :)
it will be so much easier if someone displays a finishing job for those who arent to sure?
dude, there are pics all through this thread. There really isn't all that much to it. Just cut the wire shown in the pics and connect a ground to it. If it doesn't work just solder the wire you cut, back together. easy
whats all this junk about burning out the ECU cause of a constant earth?
I have had this installed, and on, for about 6 months now... I have not noticed anything wrong with the ecu at all...
not to mention its a box that relays hundreds upon hundreds of 12V requests on an hourly basis...
1 12v being on all the time would have little to no effect on it at all...
If my vac line runs straight from the cooler return pipe to the actuator will this do anything at all like bypass the solenoid and run off the max boost setting of the actuator?? Just dont want to do this and burn out the solonoid by having it open all the time.
I've just found out that on the R34, the solenoid opens as soon as your boost exceeds 0 psi. The solenoid is in place for when the ECU goes into "safe mode", it closes the solenoid so that the boost does not exceed 5psi. Sort of like a safetyy feature rather then a 2 stage. So there should be no improvement whatsoever on R34s for this mod. Unsure about the R33s though.
Definitely works on r33
Did this mod this morning works! i just cut the black wire as close as i could to the plug, attached a lug and bolted it straight onto the chassis. No soldering, no wire extensions. easy as. reccomended for all stock 33's :)
Hi can anyone tell me if this mod works on the R32, Ive a 1990 GTS-t with the RB20det and an auto box running 10-11psi on full boost (according to aftermarket gauge) with full 3.5inch exhaust from the turbo including downpipe and de-cat and a pod filter. Sounds like a great mod but dont want to fry anything also is the solanoid in the same place on the R32. Thanx :)
The R32 doesn't have a dual boost setup... it allows full boost right through the rev range.
Edit: for some reason I thought I was on the last page, but I was on the second last page. (Can you delete posts?)
Edited by Richie33
That's incorrect..R34's are the same as R33's - "dual" stage.
Plenty of people here have done it and can vouch for it working, myself included. I even have a toggle switch hooked up so there is no doubt that it works.
Standard = Boosts @ 4-5psi til around 4000rpm then jumps to 7-8psi..with the switch flicked it's boosting @ 7-8psi from around 2500rpm.
just do it mate, you'll see! :thumbsup:
  • 4 weeks later...
I have done it. With a toggle switch with a light in-built. I have wired the setup in such a way that the light will light up when the solenoid is open. Switch on = light on = solenoid on (can hear the click). Switch off = light off but lights turn on when solenoid opens and solenoid opens the moment your pressure exceeds 0psi (have been monitoring it for more than a month now).
just do it mate, you'll see! :D
finally did it...boost comes on abit earlier, around 3000 to 3500rpm make full boost ( not excatly sure when it makes full boost, just tested qucikly)
i feel more low down torque in 1st and 2nd gear
does this sound right?
Edited by skyline17
I'm thinking of getting one of those Turbotech boost controllers, do I still need to do this mod? Was hoping for constant 9-10psi.
edit: ok, the answer would be no i don't. Anyone with experience with this boost controller? Is it a "legal" mod cops/insurance) Or should I just stick with the solenoid mod considering I'm not going to mod the turbo anytime soon.
Edited by webng
how do i install a switch?
Get a switch that is 'single polarity dual throw' i.e.
on
off
on
There will be three positions on the back to connect the wires to.
The midddle is where you connect the wire to the solenoid.
The top and bottom positions are used for a wire to ground and the wire connected to the ecu (the other end of the solenoid wire that you cut.)
It doesn't matter which of these two go at either end.
I wired mine
ground
solenoid
ECU
this means that when the switch is pushed foward, the boost is controlled by the ECU,
when it is pushed back, the solenoid is grounded i.e. full boost always,
and when it is in the middle, it will always be low boost.
There is more about this earlier in the thread I think.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
