webng Posted July 26, 2007 Share Posted July 26, 2007 (edited) Did the mod last night and went for a spin, man oh man... a lot more urgency from 2500-4500rpm. Love the sound of boost at this level too! Won't even bother wiring a switch in as there seems to be enough people on the forums that have done this mod and not have had any problems with the solenoid at a constant 8/9psi. Can't decide if it's still worth getting a Turbotech boost controller and hooking up a boost gauge though if i'm not going to bother with modding the turbo anytime soon. edit: got the tt boost controller, want to run 9psi all the time. Edited July 31, 2007 by webng Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3253096 Share on other sites More sharing options...
bluey33 Posted July 31, 2007 Share Posted July 31, 2007 Ive read this few times... Wires and I don't go together but anyhow I'm going to do it... Do you CUT the wire then ground it off... OR Do you T off the wire and ground it off... ???? Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3261453 Share on other sites More sharing options...
webng Posted July 31, 2007 Share Posted July 31, 2007 Ive read this few times... Wires and I don't go together but anyhow I'm going to do it... Do you CUT the wire then ground it off... OR Do you T off the wire and ground it off... ???? I cut it completely and grounded it for mine. Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3261561 Share on other sites More sharing options...
innocente Posted August 1, 2007 Share Posted August 1, 2007 This is how I did mine with the switch (red inverted hazard light). Testing it many many times. No difference on the R34-GTT. For the guys that did it on the 34s, are the vacumm tubes to your actuator and solenoid still stock and are the restrictors (2 small sized air restrictors that resembles small beads) removed ? I know for a fact that having the restrictors makes shitload of difference on the boost. Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3263061 Share on other sites More sharing options...
typevu Posted August 2, 2007 Share Posted August 2, 2007 Did this mod just yesterday and loving it! Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3265813 Share on other sites More sharing options...
bluey33 Posted August 2, 2007 Share Posted August 2, 2007 (edited) Just did the mod to. Cheap, easy, effective! Edited August 2, 2007 by bluey33 Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3266262 Share on other sites More sharing options...
vinnie32GTS4 Posted August 4, 2007 Share Posted August 4, 2007 im confused lol so do u cut the white wire and ground it or do u cut the black wire and ground it????? Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3268737 Share on other sites More sharing options...
Duncan Posted August 4, 2007 Share Posted August 4, 2007 cut it and ground it for sure. The other way (taping into wire) might work but it could also be giving the ecu 12v on a wire it expects to have 4v which can't be too good for it. Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3269131 Share on other sites More sharing options...
dnbutts Posted August 16, 2007 Share Posted August 16, 2007 i did this the other day, i run higher boost in low RPM but boost refuses to go anything higher than 3.5 pounds? any ideas? cheers. Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3291942 Share on other sites More sharing options...
240R33 Posted August 22, 2007 Share Posted August 22, 2007 Where can i see a pic of what the wires are supposed to look like after the mod? Do you ground the wire off the solenoid or from the ecu? Sorry, i am NO good with wiring at all.... Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3304527 Share on other sites More sharing options...
Duncan Posted August 25, 2007 Share Posted August 25, 2007 Ground the wire from the solenoid side to the chasis, this will hold it open (7psi) all the time. Leave the ecu end as is (well wrap some tape to insultate the loose end) Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3309297 Share on other sites More sharing options...
sp00nfed Posted September 3, 2007 Share Posted September 3, 2007 Did this on the weekend, car definitely feels a lot nicer to drive! Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3325954 Share on other sites More sharing options...
webng Posted September 3, 2007 Share Posted September 3, 2007 Did this on the weekend, car definitely feels a lot nicer to drive! Now go get one of those Turbotech boost controllers for $35 delivered and run 10psi all the time... "nicer" becomes "exciting"! :laughing-smiley-014: Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3326123 Share on other sites More sharing options...
RazoR33 Posted September 8, 2007 Share Posted September 8, 2007 Now go get one of those Turbotech boost controllers for $35 delivered and run 10psi all the time... "nicer" becomes "exciting"! :laughing-smiley-014: I wish it worked for me, I had one installed and it would constantly spike to 15psi under load in any gear beside 1 & 2. So I threw it in the bin and used the standard solenoid trick and now im gettin a solid 7psi all the time. Thanks for the guide btw it fixed my prob now I dont have to worry about blowing my turbo :S Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3334709 Share on other sites More sharing options...
R334door(s2) Posted September 10, 2007 Share Posted September 10, 2007 do you cut the black or the white wire can sme1 pm-me with answer plz? Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3339739 Share on other sites More sharing options...
R33 S2 Posted September 22, 2007 Share Posted September 22, 2007 hey there. just wondering where everyone grounded the wire? will the bolt next to the black plastic plug be ok? thanks in advance Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3366747 Share on other sites More sharing options...
MR 33 Posted September 22, 2007 Share Posted September 22, 2007 I can't see how you guys notice so much of a difference?? I done it, went like shit. My car hits 8psi as soon as i put my foot down then holds to 10.5psi to redline. Thats woth stocka boost controller. Different cars i guess..... Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3367029 Share on other sites More sharing options...
R33 S2 Posted September 23, 2007 Share Posted September 23, 2007 how can ya car hit 10.5 psi stock? Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3367749 Share on other sites More sharing options...
dnbutts Posted September 25, 2007 Share Posted September 25, 2007 ^^ dodgey gauge? running 10.5 PSI with a computer? if they do it? im PISSED at this mod. My car refused to go into high boost with and without the wire connected/disconnected... no idea what was happening. Greddy Spec 2 boost controller soon. Hopefully fix it! Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3372866 Share on other sites More sharing options...
MR 33 Posted September 25, 2007 Share Posted September 25, 2007 LOL dodgy gauge, idiot....... They run 7-8psi stock. Add free flowing intake and exhaust, hey presto you got 2 more psi...... Link to comment https://www.sau.com.au/forums/topic/42895-howto-rb25det-high-boost-mode-with-standard-solenoid/page/20/#findComment-3373154 Share on other sites More sharing options...
