Hi,
My 09 car is due for a service soon, but wondering what oil do you guys use?
Nissan recommends mobil 1 0w-40 but what else is available in Australia that would be suitable?
I have also seen mobil 1 0w-40 for sale from the US. Is this the same as the Australian Mobil 1? Packaging is different but I would suspect its the same
Can anyone confirm.
Thanks
https://www.sau.com.au/forums/topic/429018-what-oil-do-you-use/
Even at $100 for 5lt, Oil is cheap. Don't skimp, just use what Nissan reccomend. Why take a risk with other oil?
If you look at the UK forums there's some guys using motul oil 5W-50 and non nissan OEM transmission fluids.
I have just moved back from the UK so curious what's available in Australia and if anyone is using anything else.
Mobil 1 in the UK is about AUD 48$ for 5 litres, so $100 dollars is expensive!
I guess I better get used to the prices for oil and servicing here
Hey Snowy, is there a discernible difference in performance between 98 and P100?
Do you have to have a special tune for P100 if I'm already on a Willall Cobb tune for 98?
We actually tune the car on 98 and then run P100 for the extra safety margin as it's soley a race car. For a street car you would get a performance bonus if the car was tuned specifically for P100 over the 98.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
