Had the dyno tune today
With 'just'
- 3" Custom Cat Back Exhaust
- Pod Filter
- Hybrid 600 x 300 x 76 FMIC
- 12psi Boost
- Tweaked ECU
It made 203.5kw at the rear wheels with my 18's, is this figure way too high? Because it is still getting the dump pipe, front pipe and high flow cat put on, but still pings between 4000rpm and 5000rpm and only between there.
Could my car have internals I dont know about?!
https://www.sau.com.au/forums/topic/42912-is-my-car-a-freak-car/
dyno wouldn't give a flywheel figure....unless it was one of those chassis ones
i'm guessing that it's just very generous....
internals wouldn't give a higher power figure....unless you had some super high compression pistons, but i'm willing to bet money that that's not the case
also i'm guessing most of us here could get 20-30rwkw extra if our engines were pinging... if its pinging probbaly means it needs detuning a little which might drop you back a few kw, plus dyno may be out etc... as everyone else has said
well, i have 199.6rwkw in a VL with a minispool which is lighter than a skyline, you must have bald tyres because when i plant it rolling in second there aint no sideways action, unless i employ the services of "Mr Gearbox Destroyer"
odds are you could have 203rwkw but... you might be running like 13:1 a/f which isnt good and will be causing the ping. my advice, take it to a place that will let you drive away with a car that doesnt ping, you never know maybe they wouldnt mind doing a rebuild for you?
Evan
Dyno figures aren't worth the paper it's printed on, unless it's to compare "before and after" gains on the same car, preferably on the same day.
true, I once saw a stock GTR with 600rwkw.
Some dynos are very generous too....if you want to compare you really need to get it done on a day with others.
And I think everyone else has addressed the pinging problem....remember the "RB" in the engine name stands for "rebuild"
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
