yes, and yes I've done it.. you might just need a tad longer silicon joiner from the throttle body to the crossover pipe, but the factory one is fine too just needs to be positioned in the centre of the two pipes.
yeah i know bov location is different, i decided to buy my mates turbosmart bov (for a steal i might add) only catch is, it is made for the rb25 bov location (too tall to sit on a rb20) so im just wondering if i can use a rb25 crossover pipe on my rb20?? and how hard/easy is it to do and what do i need to change? thnx
why do you say that gtsboy? wont it work or should i not put a aftermarket bov on it?
There is plenty of info on SAU as to why you shouldn't fit a VTA BOV. Bottom line is, waste of money. Useless as a nuns c*nt.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
