UEGO is a little older and uses the LSU4.2 sensor.. hwoever has serial out which is perfect for direct integration into the Adaptronic ECU instead of using the 0-5V analog output which is inaccurate.
if you're using the serial out on the wideband to the adaptronic then don't worry, the ecu will know the sensor is offline.. if you're using 0-5 to out.. and analogue in.. when the wideband fails ecu will dump in fuel and think it's leaning out
  • Like 1
Using an AEM SCG1 boost controller and wideband for 2 years. Has been faultless. Overboost safety and lean condition safety is great.
Good stand alone unit with a 0-5V output for ECU integration. Can't fault the unit.
On 29/06/2016 at 9:05 AM, omnigear said:
happen to share the raspberri display ? I want to replace my non working clock and put a screen there for the wb gauge, but they dont make anything commercial that fits.
https://thenack.com/2015/12/raspberry-pi-car-shield/
The pics are a bit old (have switched to the official 7" touchscreen).
I've been using the Autometer wideband. Was going to use a AEM but went the Autometer as it has self calibrabation on start up.
The AEM doesnt require free air calibration. The sensor has a resistor pack that does the calibration. For 3 years i never touched mine and it was fine
Sorry Innovate SCG1. Silly me.
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
