Hi all,
I am looking to get opinions on whether the Meguires lens restoration kit is any good or not? I have faded headlights, and i think it is all external and this kit seems like a good place to start.
Is this any good, or are there other products you would recommend?
Finally, is there anything else I need, i saw something about UV protector or some such?
Cheers
https://www.sau.com.au/forums/topic/431036-headlight-restore-kit/
Hi Lemonnuff31, I had this same issue. My headlights were getting opaque with a slight yellow tinge. I didn't purchase a kit and opted for three of the lightest grit sandpapers to use in conjunction with plastX and a polish buff drill bit....think i saved 20 bucks or so doing it this way. It did the job nicely and i was happy with the result. I think with the plastics used on headlights these days the coloration and smokiness is bound to happen with exposure to UV and the elements. I don't think its a one off thing to restore headlights but a little job that needs doing maybe once every few years to keep them looking immaculate and clear. There is science behind different plastics and how they react with varying chemicals and when i cleaned mine i didn't get to finicky and just went with the most tried and tested approach. When i do mine again ill be using the Meguires Kit you mentioned.... It comes with the plasiX included in the kit.
bought the decent kit from autobarn... looked immac for about 3 months then the UV sealant started to look patchy like it was flaking off and the yellow started to return... think next time I do it im just going to use a polishing pad drill bit and buff the f**k out of them as a plastic s13 grill that was yellow turned out amazing with the buff pad
I have tried one of the kits (RainX kit). And if I had to them again, I would just be buying several fine grades of sandpaper and looking for the sealant on it's own.
I found the polish that came with the kit was next to useless. After using the sanding pads and perservering with the supplied polish, I ended up using my rotary buffer with a foam pad and a fine cut paint cleaner which did an awesome job of cleaning up the headlights after sanding. Made them look brand new. I then just applied the sealant the came with the kit. PlastX with a rotary buffer would probably work well too.
That was about 6 months ago, I live in North Queensland and my car is parked in the sun all day, and it still looks great!
Meguires do make the UV sealant on its own. Only problem is they do not sell it in Aus....YET!
Invision do not make the sealant by itself. I did ring them and they said they plan to do a bigger bottle in the future amd sell the products individualy in the future aswell.
Will the invision pack you need to be sparing with the sealant. V35 headlights are exactly small.
Lol the Meg's stuff is useless shit! Last about 3 months, and becomes worse than before a lot quicker. Their sealant is .... Okay(loosely used) but doesn't last very long.
I used the glassylite kit off eBay( $35) and it lasts about 10months to a year. Pics?
Check out this shit
Don't have any before pics as I wasn't expecting THAT good of results. But it worked wonders.
  • Like 1
  • 3 weeks later...
guys the resto kits all work great, toothpaste will work great....we need to find a good sealant which stops the degrading process and group buy.
must admit the kit i got from sprints, i think maguires, has still held up very well for months.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
