So im looking at purchasing a set of cams and iv come across these camtech cams. Has anybody heard of them? Anybody Using them? opinions will be much appreciated. Also what cams does everybody recommend using in a stock bottom end RB25 with a GT3076 .82. Making 300kw now on 16/17psi will be upping the boost to 20+psi when i decide on cams and wont be using the VCT.
Cheers, Phill.
https://www.sau.com.au/forums/topic/431071-camtech-cams/
How would 268 go on a 3076? im looking at the 264 in/ex 9mm lift.
Any advantage of leaving the VCT? wouldnt the vernier cam gear (when adjusted) be better?
Im no expert, so take it with a grain of salt, but i think they are to big and suited for 60+- to 67mm turbos
i'd use something in the 250's for a 3076 to fill up the powerband
cams need to be be matched to turbine/exhaust flow, as thats always your bottleneck....backpressure
sure you can shift your powerband to the right, but backpressure will be the one to have the final say in the matter
and nose the curve over generally, no matter how big the camshaft fitted
cheers
darren
Edited by jet_r31
  • Like 1
https://www.sau.com.au/forums/topic/431071-camtech-cams/#findComment-6996112
Looks like ill be keeping vct and going hks 256 in 264 ex with an exhaust cam gear. They look like a popular/good choice. Im after a fatter mid range and try to have a more aggressive overall power ban.
https://www.sau.com.au/forums/topic/431071-camtech-cams/#findComment-6996237
I know it does the exact same thing. But does it give as much of an improvement as lets say a vcam on a 26?
Hard to know the answer to that. Who would do a back to back with the OEM unit then a Vcam. Either would have much more twist down low than a static cam arrangement.
https://www.sau.com.au/forums/topic/431071-camtech-cams/#findComment-6996601
Same profiles as mine and at 800+HP :)
https://www.sau.com.au/forums/topic/431071-camtech-cams/#findComment-6996694
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
