Hi everybody,
(Hi doctor Nick)
it has been a while since i have been on the forums and some of the new faces might not know me, but some of you know me and my R32. You also might know my 2nd gear synchro was in less than average condition and by the sounds of it has exploded in my gearbox.... Whoops. Believe it or not, it was just driving normally when it happened, which I find hilarious!!!!
So I am need of a good condition or better, RB20/R32 gearbox ASAP. If anyone has one or knows of one please reply or give me a text on 0420 722 001
Thanks in advance for all your help, Reece
https://www.sau.com.au/forums/topic/431169-wtb-r32rb20-gearbox/
One for sale here - http://www.skylinesaustralia.com/forums/topic/431487-rb20det-manual-gearbox/
edit: whoops... thought I read NSW as his location but its WA. Sorry! :(
Edited by dontyellpl0x
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
