Hmm... I have almost got all the parts I need for my build. One thing that ive been searching for ages for is a head gasket. What is everyone's opinion on high performance gaskets vs standard OEM ones? Anyone running big power with standard ones?
I want to save some $$$ but if its crucial to buy a Cometic or something ill just do that instead.
  • Like 1
https://www.sau.com.au/forums/topic/431716-head-gaskets-vs-price/
Most of the time head gaskets let go because of detonation.. so by having that as the weakest link then it could potentially save the piston/rings which would be next in line if something went wrong.
Kind of like running street tyres vs slicks at the track. The street tyres are the fusible link, they will only take so much force before they just start baking. If you run slicks and then all of a sudden your shafts/diff/clutch need to be able to take a whole lot more force otherwise they go – if that makes sense.
With that said, I bought a Cometic 3 layer
Edited by R34GTFOUR
I am hoping for around 450 - 500rwhp. I sent an email to spool imports regarding the shipping price for a cometic gasket. Prices on Ebay seem a little expensive and plus I dont know if they are genuine or not.
Edited by Gameboy
I bought a cometic mls head gasket from Fabre Australia in Lakemba. I paid $300 for it but they were the only supplier in Australia to have a 86mm cylinder bore head gasket with 51thou thickness.
I just bought the same one from Spool Imports for $250 including shipping :)
  • Like 1
use the stocker. its fine for power even higher than that.
I used a rb26 oem one the first time, now im using a cometic metal multi layer. I have to say I liked the stocker better the difference in quench was noticable. it really depends on how much boost you plan to run and power figure.. for your goal.. it wont matter unless, as others have said, you want to save some $$$ if you need to pull the head off
Can you please explain what you mean by the "difference in the quench was noticeable"?
Providing you're using the same thickness gaskets, quench measurements should not be changed. You must be good if you can feel a quench difference!
I am making that sort of power on a stock head gasket
Edited by France
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
