Hey guys
I'm currently upgrading my front brakes to 4 pot wilwoods with 1.75" piston diametre and I don't think the standard master will cut it so I need an upgrade.
What do people normally upgrade to and what are the pro's and cons of the master?
Car is a 1989 GTS-4 Skyline with an RB20DET
https://www.sau.com.au/forums/topic/431886-r32-master-cylinder-upgrade/
I tried to google what master cylinder I had, but there's not a great deal of info on GTS-4s anywhere.
Will BMxx be stamped on the BMC somewhere I can check?
Although I could google the bore sizes of the master, it still leaves my initial question un-answered. Just because it's an available option, doesn't mean it's better than something else out there. I was more so after opinions, advice and feedback on what masters people have used and how they rate them.
Have you bought the calipers yet? If not buy the right caliper and you wont need to upgrade the BMC. BMC size isnt a performance thing...its a sizing thing. If you want better performing brakes for your Skyline you really only need to increase the heat dissipation....not the braking force. They have plenty std and are well balanced std. On an R32 perhaps they can do with a bit more bias. But you are getting that increasing the rotor size.
So what model caliper are you using . They can often be purchased with different sized pistons, get the right caliper and you are set
I have a BM50 Master.
I decided on the 1.75" (44.4mm) piston diametre, because my calipers standard are 40.4mm and I personally find them rubbish for track use. And using these calipers because they, being radial mount, allow me to run any size disc.
For the sake of the discussion what is rubbish about the std setup? Assuming you were running std caliper with 280mm rotors? What pad were you running? Did you find the stopping distance rubbish, feel rubbish, fade rubbish? All of the above?
Do you have ABS?
Sure. go to a bigger rotor, best value brake upgrade you can do. But increasing rotor size increase brake torque. If you massively increase piston diameter as well then you will be increasing the fron brakign torque by a boat load...only to have no real rear brakign torque....onlyu to have to put in a massive master cylinder or change the leverage ration of the pedal...either way you are going to need to put in adjustable brake bias to tone down the amount of braking force you have at the front which brings us back to the original point.....why increase the front brakign torque by sooo omuch?
I haven't bought any calipers or master yet, as the main reason for this post was to find out what options I have for a master if I went with my initial choice of caliper.
The brakes aren't "shit", but there is no way I'll get the times I want around the track on standard brakes. + If I'm going to use a bigger rotor, My caliper will need to be re-fit and it's easier to get a better radial mount that will withstand more punishment whilst doing so.
I currently have ABS, but pull the fuse for track use and I'm now at the stage of removal of the unit itself.
I'm currently up to about 3 pages of calculations in working out and I'm ready to pull my hair out haha. But so far, I think I'm heading in the right direction.
Will post up my findings once completed to hopefully give a better insight of the method behind my madness.
I found GTT brakes with a M/C stopper, braided brake lines, Motul RBF600 brake fluid and quality pads perfectly adequate on the track for my 18ookg Stagea so I am sure they would do for your lighter GTS-4. I only got the D2s when I got the heavier RB30 in the front together with much greater kw and speeds!
Well if you think your sizinf is correct it will be interesting to see how it all goes then. I think no matter what caliper you do if you are looking at crunching out good times and your 4dr is AWD I think 325mm rotors wont last much longrer than std, irrespective of the caliper and ducting/pads etc you use
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
