Its interesting they claim you dont need a crank collar with them. I wonder how they came to that conclusion? Im sure there a heaps of guys that have killed oil pumps due to high revs would disagree with them. Unless they have somehow moved to gears back to allow more engagement onto the crank, but I didnt think that was possible.
So a crank collar is not the same result as an rb26dett from an r34?
Without getting into a massive oil pump failure related issues thread.
The longer snout on a crank was still a bit of a band aid, the clearance to the drive was a bigger issue. This could be what they have focused on.
Well whoopdef**kindoo, Now go and find a reliable high horsepower rb pump for 80 bucks and the world will beat a path to your door.
My point is that 7.5x the price for a set of gears seems a little much. If you have ever approached a machinist about getting some parts CNC'd you would know $600 for a pair of gears is pretty hefty.
I appreciate that its their IP and they can charge whatever they want, but you did post it in a public forum in effort to spark opinionated discussion. Such is my opinion, try not to loose too much sleep over it.
As the "whoopdedoo suggests, My care (loss of sleep" factor is very low indeed, I am not promoting this product at all. As the thread title says, it looks promising given the results in other makes using this oil pump design, namely the yota J engines.
I would never ever trust billet gears.
After researching and buying a set of them (reimax) and seeing how much rediculous amount of clearance there was to the crank collar I onsold them and bought a Nitto collar and pump.
The spool gears are utter shit with poor design flaws.
Aren't the nitto pump gears a billet gear?
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
