Not sure about mic and headphones - are they bluetooth? i guess it'd just connect as a "headset" then, should be fine.
Yeah I think we should make sure the first post has a current (or at least as current as we feel like; every week or so?) list of members and what platform they're on.
i'm gonna give online another go tonight; hopefully can get a bit further.
for whatever reason my guy has dead dead eyes - thought he looked happy in the character maker now he looks like he's possessed. will try and take photos, and the f**king stupid basketball shorts wtf
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
