Hey guys can you please post your ranks in here.
A few people aren't sharing their ranks via the social club so it's hard to tell if you are an active member or not.
I'm playing around with the hierarchy because a fair few people have joined but don't play online very often
Rank 21, Social Club name is 'elementle'
me n my friend where doing the race at the prison and you get really good rp points lvled from 17-23 in about n hr or so . more people you have in the race the better rp u get about 3 bars each lap for only 3 laps tho after that theres no bonus.
if any1 wants to do it with me pm me online tag bigjobzzz
each lap takes about 25- 30 secs so race is over in 1-2mins quick way to up ur rank
Apparently R* is giving out a half a mil 'stimulus package' to make up for the online issues!!!!
Should arrive in two installments of $250,000; firstly at the next title update (sometime next week) and again towards the end of the month.
http://www.rockstargames.com/newswire/article/51565/grand-theft-auto-online-half-a-million-gta-stimulus-package-this.html
Failed at impromptu races before with manuel. False started. Didnt realise. Ill know next time
Sorry owen if I got a bit close with the machine gun on the jet. Was aiming for cars around you I swear :P
Yeah sorry about bailing on you Cal
Had a friend over with his PS so was kinda making it hard to game with others at the same time. Stole a police armoured van and went crazy in it with a super long 4 star chase.
Those things are 99% bullet proof.
Sat idle stuck on a rock for 10min before they finally killed us.
I don't understand those races because if the other person fails it then I still have to finish it which sucks big time, no way of getting out of it.
^ Yeah pretty much
I Like the extra options you have with C (still trying not to spoil it for whoever hasnt finished)
Struggling to get much time in this weekend, Been busy playing cars and pulled a truck engine apart today, maybe later I will find time to jump on
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
