money can be spent on cars and property. thats about it. guns, armour, missions, races etc all level controlled.
i'd be happier seeing more fluoro pimp mobiles around, and then you can store them somewhere. plain old apartment with 10-car garage is on the cards for me.
Really have to make more time to get on - have been crazy busy with life/work :/
yup got an hour down last night. didnt get round to much tho. tonight i have grocery shopping with the wife (yay) so wont be on.
I've got a $5000 bounty on me atm if anyone sees me before I get killed. Stole a random car on the side of the road then got a random txt message saying I'd stolen someones car then a bounty. Are these just random setups and not actually online players cars? It looked standard, parked properly and noone was around....
Auto aim system is starting to shit me. Trying to kill another person and it kept aiming somewhere else. Really frustrating.
Also did a job with Age yesterday and got killed because I hit the button to go to cover and it didnt work then pressed it again and it went to some stupid location.
Nearly hit $100k but now, keep getting stuck in the middle of all out brawls but which doesnt help
Yes to all of this. (its random setups, cause no one is going to put many genuine bounties... or would be dull for the COD types without them)
Yeah thought as much. But wasnt sure lol
Ah well someone claimed the $5000 bounty. Off to play cars in real life now, might have another go later
I like going bounty hunting, Alot of the people with bounties on them seem to be fairly easy to pick off, as long as you can get to them first
Edited by 89CAL
I always seem to miss the high priority cars to take to the docs, what do they usual get you?
also i ahve started storing hummers in the shed for when i log on, sray booth is next door and i drop one off for 5k a time without hasstles, even better if they are on the list for the docs
look for the Range Rover Evoque looking things or these Quattroporte convertible things to save. Will fetch 9k each sale at LSC
The high priority cars are sometimes not bad. Delivered one once and got $12k for it. Can't remember what it was. I always try and do them. Sometimes noone else bothers, sometimes its a massive free for all
Have managed to get a couple of crate drops now. Not as exciting as I thought but a good haul of RP points
usually when high priority vehicle pops up i let someone else pick it up, and i meet them halfway :whistling: or at the docks...hehehehe
this one time i waited RIGHT AT THE GARAGE DOOR for this guy, he arrives, sees me, is in too much of a rush to get in before i can shoot him, so he doesn't stop far back enough for the garage door to open..i walk up and shotgun him in the face, steal car, get money (7k) and then he kills me but i didn't mind since i got the 7k and he did all the work ahhahaha
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
