Plattsy and I read this
so how do i join this elite crew? you guys playing on xbox or ps3?
And we were all
But then we read this
my psn is "daninline6"
And now
Left the mod shop and looked at my cash, was thinking WTF happened here, then checked transactions and realised. Worst mistake ever. I'd have a 10 car garage apartment now if I hadn't done that lol
Pouring my $98mil into Piswasser seems to have had an affect...? share price jumped $20 in 2 days. dat $4mil profit each per character.
Also tip top tip: Tinkle is about to hit rock bottom, could make some quick coin if wanting to invest in like 10,000+ shares.
lol @ crew emblem. not even gonna buy a shirt. even though my dude doesnt wear one.
Whatever you do..... Don't accidentally buy the crew paintjob.
it's not worth the $25000 you pay for it, especially if its an accident :(
Whatever you do, don't accidentally buy the Annihilator... Thought it couldn't be bought as there was no picture.. lost 1.8mil :angry:
