Not sure. I never sent him a clutch and they looked new.?
Haha. I paid for the box.
A mate had his HKS twin rebuilt by jb and it lasted and drive very well. So not knocking the guys work. It's just I didn't have much success with the heavy single with a mix of street and track.
I've told him 1100 nm and for safety he suggested solid centre clutch not as good on street but less likely to have issues, I touched on exploding subject and he said its the centre bit can't remember exactly but the part in middle of clutch plate that usually fails and it can't in solid for some reason? But the failures reported on this forum are mostly pressure plate related it seems ? Anyway I will ask him straight out tomorrow
Was it the clutch fault or some other part that caused it?
Buy a nismo copper mix and have piece of mind knowing your car won't be a write off
I have nasty photos of one that died (not my car) and won't use one because of them
I seriously doubt the Nismo copper mix is made by exedy.
Don't skimp on the clutch
yeah kind if agree here, its not something you want to have to replace too often....that said i picked up a refurbished NPC with flywheel cheap as chips and its been faultless....wanting the best doesn't always have to mean 2500$ worth of Nismo...just means you should do your homework...
Well I will let u know how I go, I've spoken to Jim again about the failures and to me seems fair enough , these things happen and I guess it's what insurance is for in the end, he seems very honest and open about the various subjects so I'm pretty sure mine will be fine. I'm sure other manufacturers have had clutch failures but we don't hear about them, anyways looking forward to 450kw at the strip
I think youd definitely year about exploding clutches on SAU. Especially the big boys, exedy, nismo, npc, os.
Anywho, you will need a twin for 450. It would be 10000000000x nicer to drive than a unsprung clutch. Imagine taking a sledgehammer to your gearbox with every gear change. That is what 4500lb clamp load sounds like haha.
Go nismo or NPC. Both have good rep
Yep that's what he said, u guys have me suitably worried now... Is it true the excedy twin plate is same as nismo? There is one going for a good price I know of
no the nismo clutch plates are made by velo, but I doubt they are allowed to sell them to anyone but nissan/nismo
Funny. You ask the question and hear not so good revues, then do your own google search, find more horror stories and still go with mega clamp solid centre single? Make sure you have a spare gearbox is all I'll say.
Good luck
I hear you... I really do. But there are stories of nismo, npc and others letting go too, please don't think I havnt considered your suggestions but in talking to Jim he was happy to explain what happened and my tuner hasn't had any issues so I just decided to go with my original plan but actually the only horror stories are in sau in the wider google search nothing of note came up under my search queries anyway I hope u don't get to say I told you so buy time will tell
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
